Large Teardrop build 6'8"x11'8"
Postby crxtech » Wed Feb 03, 2021 8:06 am
Hey Everyone, I've been reading these forums for about 3 years. I was looking to start my first build about 2 years ago when I found a really good deal on a 5x8 silver shadow and bought that instead. Now that my daughter is 3 its just too small for the three of us. So back to building my own.
I purchased a 2006 popup (I know, I've read most of your thoughts on popup frames) for $350. I was willing to pay that much because I could easily sell the appliances in it. So, in the end I made money on the frame. The axel on this trailer is 2700lbs and set back, not in the middle. It took me two days to strip the camper down to the frame and two full truck load to the dump.
gutted to the floor
camper opened up
popup camper is home
crxtech
Re: Large Teardrop build 6'8"x11'8"
Postby crxtech » Wed Feb 03, 2021 8:08 am
There is alot of things I was able to save and plan to reuse, but these are the main two items that will save me some money.
crxtech
Postby crxtech » Wed Feb 03, 2021 8:35 am
The Frame:
The frame on this pop up is heavy... the popup was around 3000lbs with a tongue weight of around 400lbs. I tried to weight it once I removed the popup by putting a scale under the one tire and multiplying that by two and adding the tongue weight. It came to just over 500, not ideal. So I started cutting things off I don't need. The first thing I removed was a 1/4" steel plate on the tongue that was a mount for the electric host for the popup. about 25lbs. Then I cut off all the sides, this camper was 7' wide and the outter beams are 2x4" C channel. I haven't weighed all that yet, but its getting lighter. I'm doing a drop floor, so I am keeping two metal joists, one on each side of the drop foor.
floor removed
setup in the back yard
most of the metal removed
crxtech
Postby DaddyJeep » Wed Feb 03, 2021 8:41 am
I can't tell because of that piece of lumber, but did you completely remove that front piece? I am worried that you may have got a little carried away and removed all of the strength in the frame.
My big hybrid toy hauler with lots of curves build viewtopic.php?f=50&t=69618
155894
DaddyJeep
Images: 65
Postby crxtech » Wed Feb 03, 2021 8:49 am
I've been working with SketchUp and this is what I have so far. Ignore the solar panel sticking up on the roof... The front is a XL twin/sofa. The back of the sofa will fold up into a top bunk. The rear bed is a queen that sleeps front to back, that why the trailer is so long, I really didn't want to have to crawl over my wife to get out. Bothe bed platforms are 10" above the floor and the drop floor is 7.5", which should be a nice sitting height. I'm not doing a rear galley, my silver shadow has one and I find we don't use it for its purpose just store junk in it. Instead I'm reusing the popup sliders for a side slide out kitchen towards the back of the entry side of the camper. Most of the storage will be under the beds, with one set of cabinets over our feet on the rear of the camper.
interior
exterior
SketchUp (1).png (290.32 KiB) Viewed 2831 times
drop floor
SketchUp (2).png (901.19 KiB) Viewed 2831 times
crxtech
Postby crxtech » Wed Feb 03, 2021 8:52 am
DaddyJeep wrote:I can't tell because of that piece of lumber, but did you completely remove that front piece? I am worried that you may have got a little carried away and removed all of the strength in the frame.
haha, I realize that 2x4 placement is not great... No, I didn't remove the front C channel.
Also, in removing the outer sides of the trailer I had to remove the stabilizer jacks. So I'm taking the trailer to a welder soon to have 45 degree braces welded in the corners for the rear mounts for the jacks.
crxtech
Postby bartek » Wed Feb 03, 2021 6:01 pm
Darn, and I thought my teardrop was large :)
One thing which you may already know is that there are some additional lighting requirements kicking in when you go over 80 inches width. Mine was 78 inches, but after I added wider tires (and resulting fenders) it will actually go just over 80 inches.
Not a big deal, just something to remember when you're doing the electrical.
Looking forward to seeing your build progress
Image 6x10 family teardrop, build thread: http://www.tnttt.com/viewtopic.php?f=50&t=73426
bartek
Images: 84
Postby crxtech » Wed Feb 03, 2021 8:08 pm
bartek wrote:Darn, and I thought my teardrop was large :)
Thanks, I have heard additional lights are required and will have to read up on it. I'm watching your build as well and am very jealous. I used to be a member of a makerspace and use the CNC router table there. I would love to have access to that for this build, but they went out of business.
crxtech
Postby DaddyJeep » Thu Feb 04, 2021 8:36 am
Good deal. Bring it over. I would be happy to do some welding for you. Nevermind the 7 or 8 hour drive. :lol:
155894
DaddyJeep
Images: 65
Postby Shadow Catcher » Thu Feb 04, 2021 4:36 pm
Using the old converter may not be a great idea, most were hard on batteries, not three or four stage charging
Ours is a 6X10
Postby crxtech » Sun Feb 07, 2021 8:31 am
Shadow Catcher wrote:Using the old converter may not be a great idea, most were hard on batteries, not three or four stage charging
Ours is a 6X10
Thanks for the tip. I look into this specific model. What do you use or recommend using?
crxtech
Postby Shadow Catcher » Sun Feb 07, 2021 5:57 pm
We have a Progressive Dynamics PD 4045, it has worked flawlessly for 12 years. It also makes wiring easier. It is to the left of the galley the second shot was during rebuild.
163692 157758
Postby S. Heisley » Sun Feb 07, 2021 6:03 pm
Ours is a 6X10
That looks like the same model that I have. They used to have problems with those but have since fixed those problems. It's the only converter that my local RV parts store sells. Mine has been running I think 9 years. My battery is 10 years and just died this fall. I'm happy with that. If you have the money in your pocket for a USA made Progressive, go for it. Otherwise, if you know your existing converter functions okay, you can stick with it. Recognize that the dimensions of a Progressive and a WFCO are slightly different; so, if you decide to switch to a Progressive later on, you'll need to do a little cutting (not much) to make it fit.
Postby crxtech » Wed Feb 10, 2021 10:10 am
I'm finally done all the cutting and grinding metal. I'm not a fan of the metal work. I just got back from a local welder who welded in some joist I cut out and moved. All I need to do now is sand/wirewheel the frame and paint it, then I can install a floor and it might start to look like a trailer! And yes, this is my garage... At least the snow has finally melted, though its supposed to snow for the next few days again. The diesel heater raises the temp in there about 10 degrees, it would help more, but my yard isn't flat and the rear of the tent has a 6" gap.
Back from the welder
joist for step down area
rear jack brace
crxtech
Postby crxtech » Wed Feb 10, 2021 10:36 am
S. Heisley wrote:
Ours is a 6X10
Yeah, its a 2006 and still the current model sold on amazon: https://www.amazon.com/WFCO-WF-8735-P-B ... 170&sr=8-2
crxtech
