...but I think I've finally started coming across why that is.
tony.latham wrote:...but I think I've finally started coming across why that is.
Me too. They use it for the same reason they use OSB.
Pmullen503 wrote:The rigidity of the tear drop itself has to be considered when thinking about the frame. That said, I wouldn't use C-channel for the tongue.
The use has to be considered too. I would want a rigid frame for off road use to reduce the wracking forces on the trailer body itself. SUV's meant for road use are unibody, off-roaders pick something with a real frame for the same reason.
MickinOz wrote:What I don't get: hot dipped galvanised steel is as common as a common thing over here.
Why not build with it if you are worried about corrosion?
