Socal Tom wrote:Don’t worry about fancy dc/dc charging unless your have lithium batteries o
Capebuild wrote:
Actually, one other question, Swoody, the diagram you posted, shows a red marker light at the rear of the trailer and an amber in the front. Is there a reason one is red, the other amber?
John
John
1) Vehicle battery to trailer battery for charging battery on trailer.
John61CT wrote:
The amps current flow might be as high as 50-60A
requires a separate fat wiring pair and Anderson connectors
And even with a small bank suitable for a TT say 400Ah
John61CT wrote:Not everyone has a "tiny" electrickery setup, just because they might have a tiny trailer.
FYI I've got a client with a 13kW alternator charging an 1800Ah LFP bank 40+ feet away
00 AWG wiring still has to boost the output voltage by over 2V to overcome voltage drop.
I was just pointing out that - in contrast to blinky lights or the breakaway kit battery - these issues need to not be ignored when doing **any** serious charging over more than a few feet.
And even with a small bank suitable for a TT say 400Ah, will can get expensive enough to want to give it the precisely correct profile so that it lasts the 6000+ cycles it should.
saltydawg wrote:I would bet the "standard" teardrop battery is a 100 amp hour or smaller lead acid either agm or fla. So even at the recommended charge rate of 10 amps, can you charge thru the 7 pin, yes you can. But your looking at a 5 hour drive to charge from 50%. Then you do run into issues with voltage drop ( minimal ), and the alt in the car is looking at the starter battery, and the trailer battery as a load on it not something it sees as needing a charge.
saltydawg wrote:
Actually heres the funny item, you can use a solar mppt chargers as a dcdc charger. If your solar panels have diodes in them, you can just parallel them in to the solar input. This lets you use the charging profiles built into the mppt charger to charge your battery, properly. Just make sure the mppt can handle the input you expect from the alt.
