running internal lights off of a USB phone battery pack?
Anything electric, AC or DC
Postby Betonhaus » Fri Apr 02, 2021 4:20 pm
I'm wondering if the trailer doesn't have any appliances then instead of dealing with figuring out how to keep a standard car battery charged, you could have the internal wiring be 5v and use usb powered LED lights and fans throughout, which is fed by a large USB battery pack (*like 20,000+mAH or something) you could detach and plug into a charger in your car or house as needed?
Betonhaus
Re: running internal lights off of a USB phone battery pack?
Postby friz » Fri Apr 02, 2021 4:48 pm
I usually need to run a fan all night, otherwise, that would work great.
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Postby flboy » Fri Apr 23, 2021 8:37 pm
You could make one of these and charge it from your tow vehicle's Cigarette lighter. Could run LED lighting, a small fan, charge a phone.. etc.. Can also charge with a small solar panel... some call these "Solar Generators".. which doesn't make sense.. Just a portable AC/DC power pack with decent capacity. I literally just built this earlier this week. A DIY option to the Yeti or Jackery.
https://www.youtube.com/watch?v=hpAXnsKPgVM
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby RJ Howell » Sat Apr 24, 2021 6:00 am
Simple answer: Sure you can! Just remember you're only dealing with 20ah and low draw. Don't push them just because you have that amperage. Read the spec's and learn what the max draw is (and stay well below).
I made up two of these for the overlander mainly due to not having a USB port where I ended up wanting one. USB fans and reading lights are all we use them for.
RJ Howell
Images: 36
Postby flboy » Sat Apr 24, 2021 1:37 pm
That's 20ah @ <5v or <100wH .. not alot of juice.
Sent from my SM-N970U using Tapatalk
Don (Flboy)
flboy
Images: 378
Postby twisted lines » Sat Apr 24, 2021 2:26 pm
Here is one of mine & where it will stay :?
30 A ish.jpg (42.66 KiB) Viewed 1007 times
Racking up; And Rapin foam
twisted lines
Postby Sparksalot » Sat Apr 24, 2021 5:59 pm
flboy wrote:You could make one of these and charge it from your tow vehicle's Cigarette lighter. Could run LED lighting, a small fan, charge a phone.. etc.. Can also charge with a small solar panel... some call these "Solar Generators".. which doesn't make sense.. Just a portable AC/DC power pack with decent capacity. I literally just built this earlier this week. A DIY option to the Yeti or Jackery.
That was cool. I was curious why you didn’t add powerpoles too?
Sparksalot
Images: 682
Postby flboy » Sat Apr 24, 2021 6:12 pm
Sparksalot wrote:That was cool. I was curious why you didn’t add powerpoles too?
I may still do that. Easy to mod this.
Don (Flboy)
flboy
Images: 378
Postby Sparksalot » Sat Apr 24, 2021 6:15 pm
Definitely does look easy. I was curious because you mentioned radio use.
What cells and bms did you use?
Sparksalot
Images: 682
Postby flboy » Sun Apr 25, 2021 9:52 pm
The cells are made by EVE and the BMS is a Daly. My go box radios all have cigarette lighter plugs on them so they can be powered in a vehicle..
Don (Flboy)
flboy
Images: 378
Return to Electrical Secrets
