TinkerTailor wrote:I took the roof off and weighed it, putting one end of the roof on the scale, while the other end was supported on the floor, in order to mimic the weight supported while raising one end in the set-up process. The weight is only 36 lbs, But it feels like much more than that given the size and awkwardness, especially with a little bit of wind.
There is no PMF or paint on the top side, so it will be a bit heavier when all is said and done.
TinkerTailor wrote:Thanks, S. Heisley,
That's the plan. Going to get the roof back on and see how manageable it is without gas struts. I think having a push pole or something as you suggest will help a lot, so I'm going to try that as well. Thanks for weighing in with your experience!
TinkerTailor wrote:I did rip my 1X2s down to 2 inches on the tablesaw to frame the 2 inch foam.
TinkerTailor wrote: Also, I am not using the sash locks as the vintage plans called for. I'm currently using angle irons/corner braces with knob screws. I'll try to remember to take a photo the next time the camper is set up. I think I will likely change this mechanism on at least one side, and I'll update here when/if I do.
TinkerTailor wrote:That speaker stand would work, I think. I actually ordered one, but I may return it, as I tried putting the roof up after installing the wheels in the walls pictured in a post above, and it went up much more easily than before. So I think I will just need a push stick like the the marine poles discussed above. I'll post about it when I've sorted that out for sure.
I'm currently finishing the PMF on the roof, then need to install aluminum strips that will permanently connect the roof to the front/back walls.
TinkerTailor wrote:Another design consideration I overlooked if you build something like this is to build one folding side wall about 2 1/8" or so taller than the other side (with that side of the base lower by an equivalent height) so that that wall can nest underneath the other side wall and the whole assembly can lay flat when the camper is not set up. I didn't anticipate that and had to find a work around late in the game, which I'll take photos of and post next time the camper is out of the garage and set up. If this makes no sense, the photos when I get to them will help.
TinkerTailor wrote: ...
If you can get 1.5" foam easily, I think it will be just fine. Go for it! Much easier than ripping the timber. More soonish.
