LiFePO4 DIY options
Anything electric, AC or DC
Re: LiFePO4 DIY options
Postby TimC » Wed Jun 16, 2021 3:14 pm
tony.latham wrote:
Dan from Freely Roaming...
I just watched his, Battery Upgrade Part 1 video.
There's a little man on my shoulder that just said, "I hope our AGM dies soon!" The little sh**.
:frightened:
:lol:
Tony... "Die AGM die!"
And I was so happy this spring when my almost six year old AGMs where going strong. Geez!
Tim
Niagara, WI
TimC
Images: 736
Postby tony.latham » Wed Jun 16, 2021 4:47 pm
I'm the target of a conspiracy... :frightened:
T
Postby Tom&Shelly » Wed Jun 16, 2021 6:54 pm
T
This reminds me of working in the lab. One guy doing serious scientific/engineering research, and the rest of us standing around kibitzing... :lol:
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2025
Postby lfhoward » Wed Jun 16, 2021 7:05 pm
Tom&Shelly wrote:This reminds me of working in the lab. One guy doing serious scientific/engineering research, and the rest of us standing around kibitzing... :lol:
:lol: As a scientist I can appreciate that!
It’s always good to entertain the scientist. :beer:
Please stick around. You all ask good questions and bring up good points that make this battery build better.
lfhoward
Postby Tom&Shelly » Wed Jun 16, 2021 10:16 pm
Glad you don't think we're hijacking the thread! This is very interesting!
Tom&Shelly
Images: 2025
Postby tony.latham » Thu Jun 17, 2021 9:58 am
I just checked my AGM. The damn thing's showing fully charged on the AiLi meter.
:thumbdown:
Postby tony.latham » Thu Jun 17, 2021 10:13 am
I just snagged 8 of these 78 Ah Lishen units...
Hey, I'm confused. If each holds 78 amps... isn't your new battery going to hold 624 amps? Or am I failing (again) at Ohm's law?
Asking for a friend. I'm not building one. I swear. :frightened: Honest.
Postby lfhoward » Thu Jun 17, 2021 12:38 pm
You're not wrong that 624 amps seems awfully high. The magic there is when top balancing, all 8 of the 3.2 volt nominal, 78 amp hour cells are hooked together in parallel. It’s a low voltage, high amperage pack at the moment. Once top balancing is finished, the cells will be reconfigured into a 2p4s pack (2 parallel, 4 series) that is 12.8 volts nominal, 156 Ah.
lfhoward
Postby Tom&Shelly » Thu Jun 17, 2021 2:02 pm
tony.latham wrote:I just checked my AGM. The damn thing's showing fully charged on the AiLi meter.
:thumbdown:
To tell the truth Tony, I want your AGM battery to last a long time! Since I bought mine about a year after yours, if mine lasts a year longer that will prove my contention that charging from the TV doesn't hurt AGM batteries. (Okay, we may also have different discharge profiles, and I don't plan to take mine off of solar power in the Winter, etc.) But I'd be happy not having to replace my AGM battery in the teardrop ever.
Of course, I may entertain myself by building a LifePO battery for the garage, where I have no AC power...
Tom&Shelly
Images: 2025
Postby tony.latham » Thu Jun 17, 2021 2:49 pm
Thanks. I'll tell my "friend".
Postby tony.latham » Thu Jun 17, 2021 2:50 pm
So do I. I didn't buy a cheaper one for that same reason.
Now the little sh** sitting on my shoulder hopes it'll freeze to death this winter.
Postby lfhoward » Thu Jun 17, 2021 6:41 pm
Waiting for top balancing … … … it is up to 3.31 volts, which is the same place it was yesterday … … …
I created a “model” of the back wall of the compartment where the battery will live and sketched the components on it.
I’ve got the main off switch, a big fuse, and a breaker coming off the positive, and the shunt on the negative side. The inverter is the big rectangle below that stuff.
I need to mount the BMS to the front of the box, but those rods are in the way and the BMS has no screw holes in it. I think I remember people using VHB tape to stick BMS’s to battery boxes, but not to wood. I’ll have to see what I can come up with. I have a little of the white ABS plastic sheet left that I could mount there using screws, then VHB tape the BMS to the plastic surface.
lfhoward
Postby rjgimp » Thu Jun 17, 2021 11:27 pm
saltydawg wrote::surrender: :twisted:
:frightened:
:twisted: We are seeing a weakness in the force, its all going according to the plan. :twisted:
Stay strong, Tony! Stay strong...
:frightened: :worship: :frightened:
-Rob
rjgimp
Images: 7
Postby lfhoward » Fri Jun 18, 2021 7:40 am
:frightened:
“You don’t know the POWER of the dark side…” —Emperor Palpatine
lfhoward
Postby tony.latham » Fri Jun 18, 2021 9:16 am
I know I'll build one. I have to. But hopefully, it won't be for four or five years. But by then, I might be able to find the parts for a flux capacitor on Alibaba?
https://www.oreillyauto.com/flux-500.html
:thinking: And who knows what lithium cells may be going for by then.
Return to Electrical Secrets
