I used the 1/8 inch Luan plywood. Painted it white.
Sent from my SM-N970U using Tapatalk
Gonefishin wrote:Following you closely. Really curious to see the A/C unit in, and out, and every which way. I'm going to try to put something in my 6X12 that is as simple as possible. "Portable," but not necessarily one of the "portable" units that are less efficient than window units. You sound like you might just have that.
Gulfcoast wrote:I don't want to cut any ribs to install a couple of windows to peek out.
What do you guys think about vertical windows ?
They will fit between the ribs, and slide vertically with screens on the bottom.
Gulfcoast wrote:Just received two 16x14 windows for my trailer... any advice on measuring, marking, cutting and the installation with be greatly appreciated. These do have the trim ring on the inside.
Users browsing this forum: Google [Bot] and 15 guests
