Additionally, the torsion spring axle was much less controlled in is motion...
tony.latham wrote:Additionally, the torsion spring axle was much less controlled in is motion...
What do you mean by that? Less controlled?
Have you ever owned a trailer with a torsion axle? I find that they ride much better than those with springs. No argument over the Axleless axles but in full disclosure, I've never had a trailer with them.
That said, a simple leaf spring is ... reliable.
aggie79 wrote:My travel trailer has twin torsion axles. Contrary to prior posts, this is the most stable, softest-riding trailer that I ever have towed. Each of the four wheels/tires act independently. When one side experiences a dip, it doesn't transmit shock to the other wheel on the axle, and it doesn't transmit shock to the adjacent axle as happens in a two-axle leaf spring trailer. And, a torsion axle suspension does not aggravate trailer sway as does a solid axle.
Granted, I do not take my travel trailer off-road. But if I were to build an off-road camper, it would not have a solid axle with leaf springs. It would be independent suspension with coil springs and/or air springs.
My 2 cents worth. Take it or leave it.
Themontashu wrote:3) better ride. A rubber bumper will NEVER come close to performing as well as a spring and a shock. There’s a reason cars, motorcycles, mountain bikes, don’t use them.
I’ve actually never pulled a timbren setup, just torsion. I’m just speaking from data I’ve seen with rubber dampers on the timbren, combines with my torsion experience.
They're more of a sales gimmick go look at your tow vehicle whatever clearance it has that's all the trailer needs. look at all the things that are hanging down on your tow vehicle axle engine pan transmission rear end.
Tom&Shelly wrote:Just to chime in: We decided on spring suspension, on the advice of our professional trailer fabricator, as springs may be easier to come by and repair, while on the road.
I will say, to my consternation, I've seen air under our tires a few times (while Shelly was driving) including while hitting transitions to bridges on the MA turnpike at 80 mph (or the legal speed limit, whichever is lower, if there is anyone from the turnpike commission reading). Don't know if torsion axles would have helped that or not. Not sure if shocks would help, but we may think about them some day.....
