The Tiny Tillson Teardrop Trailer (T4)
Re: The Tiny Tillson Teardrop Trailer (T4)
Postby saywhatthat » Tue Sep 14, 2021 1:47 pm
Thanks for the kerf bending calculator it will help with my next build
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby Woodmaster001 » Wed Sep 15, 2021 4:14 pm
T4,
How did you treat all those cuts against water and sand/dirt/stone damage. I used herculon bed liner on my metal fenders - keeps out water between the fender and sidewall and cuts down on noise.
Woodmaker001
Woodmaster001
Postby BLTillson » Sun Oct 17, 2021 8:21 am
I have not installed or sealed them yet. When I do I will most likely use Flex Seal on the wood and then the wheel wells will be covered in .040 aluminum.
Woodmaster001 wrote:T4,
Woodmaker001
~BLT~
Δοξάστε τον Θεό από τον οποίο πηγάζουν όλες οι ευλογίεςt
BLTillson
Images: 18
Postby BLTillson » Sun Oct 17, 2021 8:24 am
You are welcome. Perform lots of tests before you commit to using expensive lumber. Reaching your desired radius and having all the kerfs closed down to nice sealed triangles can be a challenge.
saywhatthat wrote:Thanks for the kerf bending calculator it will help with my next build
~BLT~
BLTillson
Images: 18
Postby BLTillson » Sun Oct 17, 2021 8:26 am
The wood will be sealed on all sides. The wheel side of the fender will be covered in Flex Seal and then .040 aluminum.
Woodmaker001
~BLT~
BLTillson
Images: 18
Postby BLTillson » Sun Oct 17, 2021 9:34 am
Not much progress being made over the past few weeks due to some health issues. I have made some advancements in support systems. I needed to move the operation inside so we purchased a 12 x 20 x 8 carport. I also made a trip alarm since I live in an area that warrants the protection.
Hopefully construction will continue soon.
Shelter Logic Portable Carport.
New Carport.jpg (219.93 KiB) Viewed 721 times
DIY Alarm
Proximity trip alarm.jpg (172.13 KiB) Viewed 721 times
Alarm installed
Trip alarm set.jpg (93.8 KiB) Viewed 721 times
~BLT~
BLTillson
Images: 18
Postby BLTillson » Wed Feb 09, 2022 10:12 am
I have finally been able to get back to work on the project. Here are some of the highlights of the progress I have made.
First was the completion of the tank cradle. It is only going to be an 11 gallon tank, however, that is 91 pounds full and will be the lowest part of the camper and closest to the road. It will also be covered with .040 aluminum.
Tank cradle welded in. Don't look too close. I learned to weld this year.
Tank Cradle.jpg (207.55 KiB) Viewed 583 times
Next I installed the water tank box. I will not be installing the water tank and pumping system with the initial build due to cost. With rising costs on everything the whole water system is too expensive. Should have bought it all back in 2020. :cry:
Floor with water tank box installed. Finally!
Floor with tank box.jpg (165.01 KiB) Viewed 583 times
It feel really great to be back to work on this. We hope to have it done for a vacation in September.
~BLT~
BLTillson
Images: 18
Postby BLTillson » Wed Feb 09, 2022 10:25 am
Sealed the bottom of the trailer with Flex Seal. This is the first coat. Once I have cut out the fender wells and made sure that all fits I will put on a second coat before attaching the floor to the trailer. That will be a great day.
Flex Seal bottom.jpg (213.69 KiB) Viewed 584 times
Flex Seal Can sm.jpg (35.8 KiB) Viewed 584 times
Finally made the critical cuts into the floor for the fenders. I have been working toward this part with great anticipation. The underside of the fender wells and the side walls will be covered with .040 aircraft aluminum. I was concerned about the tire clearance. What do you think? I have figured out how I would increase the clearance but it would be a bunch of work (rework). I will be performing some weight test along the way.
Fender fitting.jpg (175.42 KiB) Viewed 584 times
Lord willing I will be able to keep up the current pace on this wonderful project.
~BLT~
BLTillson
Images: 18
Postby saywhatthat » Wed Feb 09, 2022 12:23 pm
when you realize you need to remove seal flex nylon wire wheel works the best . At shop that is the main reason we see floor rot out
saywhatthat
Images: 135
Postby tony.latham » Wed Feb 09, 2022 12:40 pm
For a Dexter torsion axle, I build in 4" of clearance. And that's before I add the cabin (weight) to the chassis.
:thinking: It's pretty cool how you've done it.
Postby BLTillson » Thu Feb 10, 2022 1:52 pm
Thank you Tony. I spent a long time in SketchUp working on that design. When I get back out to the project I will measure. I think I am maybe at 4", possibly 3". This is the time to fix it before I go further. I have done lots of woodworking but nothing that had to move down the highway!
~BLT~
BLTillson
Images: 18
Postby BLTillson » Thu Feb 10, 2022 1:54 pm
Thank you for that advice. I am impressed already with how tough Flex Seal is. Once the floor is attached to the trailer for good I will flip the trailer and do all the fill in work and make sure it's sealed tight.
saywhatthat wrote:when you realize you need to remove seal flex nylon wire wheel works the best . At shop that is the main reason we see floor rot out
~BLT~
BLTillson
Images: 18
Postby MickinOz » Thu Feb 10, 2022 3:05 pm
Are you saying Flex Seal causes floor rot?
MickinOz
Postby saywhatthat » Thu Feb 10, 2022 3:18 pm
Yes you can get Nicks and scrapes and scratches . that will let water get in and be absorbed by the plywood. even condensation in the pores of the plywood . Can't dry out your start getting little bit and lift in plywood . more water. Most of the trailers that have rot that don't have leaks from above it's because they have sealed the bottom of the floor
saywhatthat
Images: 135
Postby MickinOz » Thu Feb 10, 2022 3:34 pm
So you think the floor should be left raw timber underneath?
MickinOz
