I would never leave raw (expensive and painstakingly crafted) lumber exposed to the horrors of miles of road abuse.
BLTillson wrote:This project has been challenging from the standpoint of all the skills I have needed to learn to accomplish success.
Tom&Shelly wrote:BLTillson wrote:This project has been challenging from the standpoint of all the skills I have needed to learn to accomplish success.
That described Shelly and me, and probably most of us, at the stage your build is in. Fun challenges though, no?
Looking great!
Renogy 10 Amp 12V/24V PWM Negative Ground Solar Charge Controller...
tony.latham wrote:Renogy 10 Amp 12V/24V PWM Negative Ground Solar Charge Controller...
You might check the manual, but I think you'll want to install a switch between the panels and the controller. My Renogy can be damaged by disconnecting the battery while the panels are making juice.
True of all the controllers I have seen!tony.latham wrote:Renogy 10 Amp 12V/24V PWM Negative Ground Solar Charge Controller...
Tom&Shelly wrote:I suggest you move the fuse from the charge selector switch to the right, so it's right in front of the battery. Physically that's where you want it as well, so that if the positive wire accidentally shorts to ground there is a fuse to protect the batteries. For lead acid (including sealed and AGM) a 30 amp fuse is appropriate. For the various lithium flavors, I don't know, but others here do.
You won't get 270 amps from the tow vehicle alternator with lead acid batteries. Less than 10 amps will be about right (it depends on the difference in voltage between the alternator and camper batteries). And, though others will disagree, about 10 gauge wire there is fine. (With the charge current you will get, the voltage drop with 10 gauge wire isn't enough more than larger wires to make it worth the problems of running that larger wire.)
Of course, if you want, you can make that part more complicated and run large wires from the alternator in the tow vehicle. To make that worth-while, you'd want to add a DC-DC converter to up the charge voltage at the batteries. The upside is that the charging will go a lot faster. (I do it the simple way, but we're okay with taking 5-6 hours to get our battery from 80% to 100% charged.)
Again, if using lithium batteries, that part gets more complicated and you'll need some more electronics for charging from the tow vehicle to limit the current so you don't blow up the alternator.
