bdosborn wrote:I use Minwax polycrylic satin for interior finishes using a Harbor Freight HVLP sprayer to apply it. Best finish I've ever been able to pull off, much easier than spar urethane to use.
bdosborn wrote:It is surprisingly easy. I set my line pressure to 40 psi. There's a couple of knobs on the side of the sprayer that you'll need to tweak to get the spray pattern you want. You probably wont have to fiddle with it again after you get it setup. I usually do three coats and sand very lightly between each coat. Don't skip the sanding, it doesn't turn very good if you do. I pour the leftover paint out of the sprayer back in the can and clean it out in the sink between each coat.
