GPW wrote:After trying both , we found out we like neither... Both need some kind of treatment to survive... We went to using boards instead ... we used boards for our trailer floor and no problems , and if anything goes awry , they can be replaced one at a time ... Originally we had an OSB floor and that didn't last ... In our Damp climate , plywood always eventually delaminated , despite different waterproofing attempts.
Just plain pine boards?
GPW wrote:Steam , they were "clear and dry" treated pine, well primed and painted , However I have an old all steel cargo trailer with a plain board floor ( untreated, unpainted ), that's still in great shape after many years . I do believe the key is , the sides extend down past the floor , so the floor almost never gets wet .
tony.latham wrote:Just plain pine boards?
Keep in mind that boards –-unlike plywood-- swell and contract width-wise as the moisture content changes. I've got a wooden deck on three sides of my home. There's a reason it was installed with gaps. If they were installed without gaps, there would be real issues. Sometimes the gaps are 3/8" and sometimes they are 1/4" depending on the weather.
I've got a utility trailer that's decked with 2" x 6" fir. The same thing happens.
We haul our camper through rainstorms that expose the undercarriage to torrents of moisture and over super-dusty roads. And of course, no dust or moisture gets inside. (The bottom of the plywood floor is sealed with epoxy.)
We caulked between our boards ... No problems ...
