Window question - weep holes
Postby philpom » Tue Feb 14, 2023 6:25 pm
I feel like I should be able to find this info easily on the web but I haven't been able to....
My windows are left to right sliders. There are 2 rubber plugs at the top and at the bottom. I assume these are in the event you mount it up side down. These are weep holes and they should be removed along the bottom edge correct? I really feel that is the right answer but since I can't find definitive information I felt compelled to ask here. Plus the camper was left out in heavy rain last night and it got me thinking about this again!
Plugs in place:
Plugs removed:
philpom
Images: 101
Re: Window question - weep holes
Postby Pmullen503 » Tue Feb 14, 2023 7:29 pm
Yes, you should remove them so the tracks can drain.
Pmullen503
Images: 67
Postby Onajourney » Wed Feb 15, 2023 8:53 am
Pmullen503 wrote:Yes, you should remove them so the tracks can drain.
Just the bottom ones
Onajourney
Images: 181
Postby philpom » Wed Feb 15, 2023 9:47 am
Thanks guys, as obvious as it gets but the windows only arrived with air in the box!
philpom
Images: 101
