Good As NEW!Had a chance to work on the frame over the weekend. Managed to fully clean, grind, and sandblast the old frame. Luckily all the rust was surface rust, and it cleaned up pretty well.
Once the frame was clean, I wiped the whole thing down with alcohol and then painted it.
- Before and After
- Frame Before and After.JPG (78.48 KiB) Viewed 650 times
I used POR15 on the frame.
POR15 is NOT cheap ($60/Qt), but in my opinion, WORTH EVERY PENNY! I was really happy with how well it coated and how easy it was to apply.
I managed to get 2 coats on the frame with ONE QUART. Once the POR15 dried to tacky (approx 2hrs as suggested on their site) I applied 2 coats of rattle can Black Implement paint. (1 can each coat)
This is the spray paint I used for the "Top Coat":
https://www.acehardware.com/departments/paint-and-supplies/spray-paint/general-purpose/17072For the springs, I applied 3 coats of Engine Paint. (Found this as a recommendation online somewhere...)
Here is the paint I used for this:
https://www.acehardware.com/departments/paint-and-supplies/spray-paint/hobby-spray-paint/1498161For the axel, I applied one coat of POR15 then one coat of Engine Paint, just because...
- Axel and Springs
- Axel and Springs.JPG (28.68 KiB) Viewed 650 times
We also worked on the suspension. The 50 year old shackles and bushings were well past their prime and seized up, so we broke all that loose and rebuilt that.
Finally, just for fun, we weighed the frame. Turns out the 1971 Skamper FRAME weights almost exactly 150lbs!
- 150lbs
- 150lbs.JPG (75.71 KiB) Viewed 650 times
Frame: 150lbs
Axel: 25lbs
Springs: 12.5lbs each (2)
Wheels: 25lbs each (3)
That puts my total weight so far at: 275lbs My goal is Under 3000lbs loaded, so it looks like I have a good base!
It is going to be a few weeks before I get back to the frame, in the mean time, I need to make some key design decisions, mainly... FLOOR.
We have a few boxes of TEAK hardwood floor that we could use. I am worried about weight with this option... it is nearly 250lbs for the floor if we use the teak hardwood.
The other option is commercial grade linoleum tiles... I like the black and white checkered look... this costs more (as the teak is FREE) but it weights less!
Open to suggestions!
Cheers!
