dardack wrote:.......... I don't think she'll be able to reach if it opens up to close back.. was thinking of getting a 270 awning attached to roof rack that would cover side and back and have back open horizontal.. however that's a lot of weight so was.wondering if anyone had any thoughts....
Pmullen503 wrote:dardack wrote:.......... I don't think she'll be able to reach if it opens up to close back.. was thinking of getting a 270 awning attached to roof rack that would cover side and back and have back open horizontal.. however that's a lot of weight so was.wondering if anyone had any thoughts....
I assume you mean the back door swinging sideways rather than up. I have that on mine and I'll give you my experience. First off, it does put some stress on the body. If you plan to have a back wall to the cabin, make sure it's well secured because the door will introduce a racking force to the back end. The wall that separates the cabin from the galley will be structural so solidly attach it to the sides.
Secondly, that door can blow around in the wind. I had to rehinge mine so I could swing it all the way around (270 degrees) to bungee against the fender when open.
The solution to both those problems is to make double doors. That way the weight is carried on both sides (and less weight of each to boot.) Since each door is narrower, they can swing flat against the sides and so easier to secure. More to do to seal and secure, but you don't need lifters. You could introduce some mechanism to lock them at 90 degrees when open which would shelter the galley from the sides if you want as well.
tony.latham wrote:Well... traditional teardrop galley hatches have worked superb for eighty years.
Something to consider.
that you had like an extra bar for your lights on the rear of the trailer (at least the picture looks like it's an extra bar). If you go over this in the book, I can wait, just curoius what that was.
[/quote]Also I did want to ask, i've seen your posts with your 11lb propane in front with the regulators on the box, 1. They won't rust? 2. Did you run the hoses under the trailer and no concern for damage from road? (I think you mentioned rubber, not black steel, I was thinking of doing black steel under and just repainting once a year).
tony.latham wrote:
And about building an angular teardrop. Angles are harder than curves and not as strong. (And if you go to the beach, you'll find they are better looking. ) I seldom see a squareback with a great galley. And to me, what defines an individual teardrop, is the galley.
But... build what makes you two happy.
tony.latham wrote:Regulators are made for exterior applications. Rust isn't an issue. The propane hoses are rubber--as recommended by my friend who was a professional propane guy for thirty years. There's no question in my mind, it's the way to go. You could use black pipe, but every joint is a potential leak point and you'll have lots of elbows. Rubber is easy and it's not a problem with flying rocks.
Tom&Shelly wrote:tony.latham wrote:Regulators are made for exterior applications. Rust isn't an issue. The propane hoses are rubber--as recommended by my friend who was a professional propane guy for thirty years. There's no question in my mind, it's the way to go. You could use black pipe, but every joint is a potential leak point and you'll have lots of elbows. Rubber is easy and it's not a problem with flying rocks.
BTW, they make a flexible hoses for propane that have a braided metal sheath for extra protection. That's what we used and it works fine. Found it on Amazon (but now when I go to "past purchases" it's showing something different, so I can't give you a link, but there are others on the site). It was a foot or so longer than we needed so we snaked it around under the tear a little.
But, we've found the underside of the tear doesn't take as much abuse as we'd expected.
BTW, they make a flexible hoses for propane that have a braided metal ...
I was thinking I needed UL21 cause DOT reg's? IDK. I was going to run it inside PVC pipe to give it protection under trailer if not using black steel.
tony.latham wrote:I was thinking I needed UL21 cause DOT reg's? IDK. I was going to run it inside PVC pipe to give it protection under trailer if not using black steel.
I think you're overthinking this. It doesn't need to be in PVC pipe. Just like your tires, rubber takes a beating. The hoses are connected to the bottom of my floor using adel clamps.
Users browsing this forum: Google [Bot] and 7 guests
