Thanks for posting your process. I'm looking at some of the videos. I'm planning to use ACM or marine plywood, or Baltic Birch skins. But I'm having trouble finding the plywood.
Do you recommend the ACM now? I'm trying to stay under 1000 lbs. 1/8 plywood is lighter, but I can't find any locally that are exterior grade. 1/4" BCX plywood is about the same weight. It might be easier to work with, but then it needs to be finished.
I plan to trim out the exterior with western red cedar trim.
My design will fold down, but you can stand up in it once its up.
I bought some cork to insulate with, not sure how well it will work. Good sound attenuation. No mold/mildew issues with cork usually. All natural too.
Good luck as you continue.
Matthew in Memphis
Hi Matthew,
I would use the ACM again but I would design the camper to fit the sheets, all we have here locally is 4x8 sheet and they had 3 sheets left of 5x10
I saw another guy locally who built a smaller one and his was only 5' wide he used 2 5x10 sheets and only had one roof seem in the middle - made the bending much easier.
If you plan to trim it out with cedar, I'm not sure if ACM is worth it, we used it because it can act as the siding as well.
So many options, I'm sure you'll figure out what will work best for your build
