What did you do today
Re: What did you do today
Postby rjgimp » Fri Feb 02, 2024 11:33 pm
twisted lines wrote:Snow's finally gone, someplace's :?
I believe I have that exact same battery charger. Mine has 2 switches- either 6 or 12 VDC and either 2 or 10 amps. I've had it for around 30 years.
-Rob
rjgimp
Images: 7
Postby twisted lines » Sat Feb 03, 2024 1:07 pm
rjgimp wrote:I believe I have that exact same battery charger. Mine has 2 switches- either 6 or 12 VDC and either 2 or 10 amps. I've had it for around 30 years.
& 50 Amp for Jump start. been a good one, the timer is a little in question sometimes it works; sometimes Na.
Racking up; And Rapin foam
twisted lines
Postby twisted lines » Sun Feb 04, 2024 5:14 pm
these are the last pictures I have taken,
it shows how rusty the anode or sacrificial piece turn's
have seasoned it but not finished.
twisted lines
Postby Tom&Shelly » Wed Feb 28, 2024 3:27 pm
We have this folding portable grill
173202
which works great when you leave the legs folded and prop it on rocks. I mean, it's 11 inches tall! Who tries to cook food that far from a fire? And it's not a new problem either. I have a book on camp cooking from the mid-1950's and the author said he cut the legs off and used rocks. So this product defect has been around for 70+ years! So time to stop carping about it (that was how the hep cats said that back in the mid-1950s) and do something.
Admittedly, the "prop it on rocks" solution works great when you have rocks. Problem is we occasionally camp in some pretty civilized places where they evidently trucked away all the natural born local rocks and replaced them with concrete. So I took some scrap angle iron and made this
173203
We'll see how it works. I hope the bolts stay tight with repeated heating. Welding would have been better, and if this works out, Mark II might be one of my first attempts as I learn (after buying the equipment).
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Postby bdosborn » Wed Feb 28, 2024 4:21 pm
Tom&Shelly wrote:Welding would have been better, and if this works out, Mark II might be one of my first attempts as I learn (after buying the equipment).
It's tradition that the first thing you make with your new welder is a cart for your new welder. :thumbsup:
Images: 777
Postby Tom&Shelly » Wed Feb 28, 2024 6:40 pm
Even better! The grill can be Project 2. :D
Tom&Shelly
Images: 2021
Postby TimC » Sat Mar 02, 2024 3:37 pm
With our weird weather I've been busy this winter getting Eastern Bluebird and Saw Whet Owl nest boxes built. Today I finished installing two Saw Whet nest boxes next to the Menominee River (WI/MI border). IT was two trips of a little more than a mile one way carrying the nest boxes and then a ladder and tools to get them at least three meters up a tree trunk. I installed a trail camera at each and hope to check back once a week to see if there are any takers.
The Northern Saw Whet Owl is the second smallest owl species in North America and has been on the decline due to habitat destruction. While there is a wide swath of the northern US and southern Canada where the Saw Whet breeds they do migrate to the central US in the winter.
In addition, I built 14 "Gilbertson PVC" nest boxes to add to my Bluebird trails I started last year. In 2023 I had 21 "Gilwood" nest boxes up at several trails. I had 9 pairs producing eggs (two pair produced a second brood). Total of 49 eggs, 46 hatchlings and 46 fledglings. That's in addition to two Tree Swallow pairs and one House Wren pair producing broods. A successful first year. I hope to double that production in '24 now that I have some experience with nest box locations. I'm also hoping to get some help monitoring these boxes. 21 boxes last year kept me very busy.
Gilertson nest boxes are named for a Minnesota Bluebird "Citizen Scientist" who developed his designs after many years of trial and error. The Gilwood is a standard wooden box made of pine or cedar. The PVC version was developed to combat invasive species like the European Starling and the House Sparrow which like to kill bluebirds in their nest and then take over the box. The PVC design has proven to help as the Starlings won't fit and the Sparrow does not like the design for some reason.
Tim
Niagara, WI
TimC
Images: 736
Postby tony.latham » Sat Mar 02, 2024 4:43 pm
I finished installing two Saw Whet nest boxes...
I'm jealous. I've had a screech owl box on our place for three years with no activity. Obviously, it's in the wrong spot.
Postby Tom&Shelly » Sat Mar 02, 2024 8:35 pm
TimC wrote:The PVC design has proven to help as the Starlings won't fit and the Sparrow does not like the design for some reason.
Sparrow's instincts tell them to "go sit in the corner"?
Tom :thinking:
Tom&Shelly
Images: 2021
Postby TimC » Sat Mar 02, 2024 8:37 pm
Tom :thinking:
Ha ha! You might be on to something!
Tim
Niagara, WI
TimC
Images: 736
Postby Tom&Shelly » Tue Mar 05, 2024 6:42 pm
Actually started this project in December, but life got in the way for a few months. Anyway, I decided to give the utility sink area of our shop a make-over
Before
172829
After
173225 173226
Paid nothing for it. Two of the shelves are from the crates our teardrop doors were shipped in, the deeper one across the top was a scrap board a neighbor was giving away. The under-counter LED light over the sink was from a lot of returns I'd bought a few years ago from a surplus place in Albuquerque for another project, at 10 cents on the dollar. Don't remember where the shelf brackets came from, but they were taking up room with the rest of the miscellaneous hardware in the shop.
Still have to re-hang the first aid kit. Hope I can drill into the concrete without needing the first aid kit! I'll probably move the outlet as well. It was getting expensive using the blue shop towels for everything, so made a holder for regular paper towels for times when lint isn't an issue. Oh! Shelly tells me paper towels are now becoming so popular some companies are actually making holders for them, and so you don't need to make them out of scrap wood. For those of you who are made of money!
Tom&Shelly
Images: 2021
Postby twisted lines » Tue Mar 05, 2024 8:24 pm
Tom&Shelly wrote:We have this folding portable grill
If you wear it out & we cross paths;
I have a rat hole of Laser welded Stainless
I bend the ends and give them away instead of washing :lol:
twisted lines
Postby twisted lines » Sat May 11, 2024 5:42 pm
Northern lights !
I am on the southern end but in the zone; last night was the 1st I have seen them :o Will be out again tonight :thumbsup:
twisted lines
Postby Gold5one » Tue May 14, 2024 10:28 pm
Sadly- no northern lights for us in Florida.
It took me 3 weeks on and off to install this floating screen radio in my 2003 Durango - I now know why auto-sound radio shops do not want to install the wires and backup camera - a royal PITA for a 74 yr old guy- it all worked - only took me 3 weeks on and off to do this - the local shop wanted $300 to do this - but not camera - so I did it myself - Walmart had been clearancing this discontinued radio model out, I bought mine on eBay for $119. The heat index was 101 degrees in SW FL this afternoon . It’s a BOSS BCPA8 radio AND the Apple CarPlay SiriusXM iPhone app works fine - I am now a safe driver in the parking lots with a backup camera !
:shock:
173517 , 173518
173519y
Mark
viewtopic.php?f=50&t=74522
Weekender-XL build journal
sold-2018
Gold5one
Images: 157
Postby pchast » Wed May 15, 2024 9:09 pm
verrrry nice.
pchast
Images: 97
