on Jan.09, 2024, from another thread:
ScottM wrote:I'm in the planning stages right now for a larger trailer. The dimensions are still TDB but 14-16ft long by 7-8 feet wide.
Is the boat trailer frame the same one you had earlier planned to use, or has your design plan changed? Most boat trailers (single-axle) are smaller, but are you using a double-axle boat trailer?
I found some drawings on the Karavan Trailers website, to use as a visual sample of a larger, single-axle boat trailer (3100 lbs). With one like this, you could easily build a large cabin atop the existing framerails, using 3/4" plywood spanning the rails, and with dimensional lumber added to the slides underneath (to bring their height up to the level of the framerails. if different, as support for the plywood flooring}. Simple Tek screws could be used to screw-down the plywood to the steel frame (I used 38 to screw my floor down to the perimeter of the frame, plus PL adhesive in between), with no need to weld-in angle iron supports.
- boat trailer as a large TTT frame.jpg (114.91 KiB) Viewed 533 times
Plywood has a high resistance to bending, especially with some support structure underneath. When designing my trailer, I wondered how large my roof could be (side-to-side, front-to-back, without conventional spars underneath (I used small steel gusseted angle brackets on the sides and rear inner bulkhead, with the front supported by a mitered cut edge abutting the sloped front part of the roof, which was also supported in a similar manner...PL adhesive was also used everywhere). The largest section was about 50"L (as far I remember) x 46.5" (the piece was actually 48" wide, and laid atop the walls and rear bulkhead, ending up as 46.5" between the sidewalls). I used an online calculator, called the
Sagulator https://woodbin.com/calcs/sagulator/, normally used to determine the strength and sag resistance of shelves (what is the difference, between a shelf, a flat roof, or a floor anyway)?
My roof has never sagged, even supporting my 225 lb. weight on the roof, without spars, so the
Sagulator must work. Using it, you can figure out if you'll need more floor support, or where to add it.
Referring to the sample drawings, you could use three 4'x8' sheets of 3/4" plywood (or, if you camp in cold climates, a sheet of foam board sandwiched between thinner 1/4" or 3/8" plywood sheets, for insulation purposes).
I built my trailer for strength only, with modifications added for minimal insulation work-arounds, later on. Three sheets would be cut down to 80" x 48", and laid atop the framerails, giving you a 6.5"W x 12' L floor to start with (in my case, I put my sidewalls directly on top of the floor, with PL in between and the edge grain of the floor sealed with "the mix" and enameled-over), but if you wanted the sidewalls overhanging the exposed end/edge grain of the flooring, you'd need to reduce the 80"W measurement, somewhat...the front-to-rear 12' measurement will work in either case, unchanged.
I like to think of and make outside-the-box designs and modifications to cars, trucks, and my trailer...my wife won't let me fiddle with
her house nor
her car, but so far, 99% of my constructions have worked for me. Maybe you'll find an idea, here, to use.
