a/c hanging out in the front (any advice good or bad)
Postby dhazard » Mon Oct 30, 2006 10:32 pm
Hi John, I have my A/C out the front. I used expanded metal on the bottom and will add vents to the top of the sides. I am planning on a Honda 2k generator sitting next to the A/C, so my axle is a little closer to the front than most to keep the tongue weight down. The A/C unit that I have blows almost strait up, no problem with freezing the top of my head… but with a 5200 btu A/C everything might get a little frosty. :snow Good luck with your build. Dan
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
