opinions on my art deco fender...
Postby Dean in Eureka, CA » Fri Nov 03, 2006 6:57 pm
Which one looks better?
#1
#2
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Steve Frederick » Fri Nov 03, 2006 7:05 pm
Do they protrude from the body, or just applied to the wall?
I like the top one!
I like the bottom one!
If they protrude, I like the top one in that case.
How about a full view?
Nice work!
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Gage » Fri Nov 03, 2006 7:07 pm
Top one. :yes:
Image Image Image
Gage
Images: 28
Postby madjack » Fri Nov 03, 2006 7:08 pm
...da top...................................... 8)
Postby PaulC » Fri Nov 03, 2006 7:19 pm
Dean, I'm known as a bottom's man :shock: but in this case I prefer the top :lol:
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Nitetimes » Fri Nov 03, 2006 7:30 pm
'Nother vote for #1
:thumbsup: :thumbsup:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Dean in Eureka, CA » Fri Nov 03, 2006 7:30 pm
Steve,
I don't know how to use THAT drawing program yet. :lol:
They will be mounted to the side wall and project out about 9 1/2" or so... same type of look that a Camp-Inn fender has, except the rear deco area will be a separate compartment with a flip up lid for either storage or an ice box for the kids sodas. The fenders, where they meet the side wall, will be trimmed in lighter trim.
At least I'm set on the location of the accent stripe. I'm going to incorporate that two piece bead and cove stripe into the lighter trim. Nixed the full bead and cove side wall, using 1/4" ply exterior skins now.
I just picked up the ply. The bottom darker area will be african mahogany, dyed dark red and the upper area will be red birch, dyed yellow. I hope to get the wall frames skinned this weekend.
Fender #1 allows for the dark red to carry through as where fender #2 comes up to the applied accent stripe.
These mahogany sheets are incredible. The "back" sides of them look more like laminated lumber and are heavy with fiddleback. :twisted:
I'm gonna do some tests with the dye to see how that side looks... my hunch is that it's gonna look awesome, but I don't have the balls to go for it without doing a test with the anyline dye first.
I bought seven sheets of marine grade hydrotech last week and was going to go vertical with the grain with lighter trim at the vertical joints, but found two problems... 1 the hydrotech has filler putty on both sides and 2. didn't work out too well with the dye on the upper color.
Now that I'm using two different types of ply, I'm going to go horizontal on the grain orientation and the only vertical joints that will need an applied trim are above and below the center of the doors.
I will post photos after I get the walls dyed.
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Juneaudave » Fri Nov 03, 2006 7:38 pm
The top!!!! Why did you change from bead and cove? I was looking forward to a matching Redbird. BTW....I gotta send you some pics of my fender disaster, just for laughs. My suggestion would be to take some cardboard or cheap ply and mock them up before you build...Take care...Juneaudave
Juneaudave
Images: 380
Postby Dean in Eureka, CA » Fri Nov 03, 2006 7:46 pm
Dave,
1/4" ply is way faster for this slow builder and this thing must be at least towable and usable in time for the 14th Dam. :o
Oh no... You had a fender disater???? :(
Another good thing about going with the ply instead of canoe stripping, is I'll be able to get it done faster and won't have more time to change my mind anymore than I have already... Other big change: nixed half of the dinette. (Rear section) That area is now gonna have a cabinet above the bed and the table has changed bigtime. It's now smaller and will tuck under the rear cabinet on slides when stowed... no more pedastal.
Hey... The accent stripe will still tie the Redird and the Chieftain together.
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby lcurrie » Fri Nov 03, 2006 7:59 pm
#1
lcurrie
Postby JunkMan » Fri Nov 03, 2006 8:38 pm
Top :thumbsup:
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby sid » Fri Nov 03, 2006 9:22 pm
Top..... :thumbsup:
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby Cary Winch » Fri Nov 03, 2006 9:32 pm
Got to go for the top one, low and lean.
Cary
Cary Winch
Teardrop Manufacturer
Postby asianflava » Fri Nov 03, 2006 9:39 pm
asianflava
Postby Dean in Eureka, CA » Fri Nov 03, 2006 11:06 pm
Thanks Everyone,
Looks like low and lean w/lower color carrying through wins.
I'll shoot for 3 1/2" of clearance on the fender and tire for the swing arm travel...
Dean in Eureka, CA
The Fogcrawler
Images: 69
Return to User Polls
