Window Repair
Window Repair
Postby Spadinator » Thu Nov 09, 2006 5:04 pm
I have been working on my slider windows for the trailer and have discovered that they are broken. There are 4 little plastic clips that center and keep the window in it's frame that are broke or missing. Does any one have any idea where I could get new ones or how to repair mine. :thinking:
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Postby halfdome, Danny » Thu Nov 09, 2006 10:26 pm
I did a search with no luck :( . Does the window have a manufacturer name that you could do a search on? :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Spadinator » Fri Nov 10, 2006 12:44 am
Well Danny they are HEHR windows...there is a website for them but nothing supporting older windows. They don't list repair or parts on their website. I am hoping I don't have to scrap them because my doors are cut to fit them.
Spadinator
Images: 47
Postby Micro469 » Fri Nov 10, 2006 8:19 am
Spadinator wrote:Well Danny they are HEHR windows...there is a website for them but nothing supporting older windows. They don't list repair or parts on their website. I am hoping I don't have to scrap them because my doors are cut to fit them.
Can you show us a picture of them? And of the clips? :o
John
Micro469
Images: 382
Postby madjack » Fri Nov 10, 2006 10:17 am
Spad, email Hehr directly and ask...also, many auto side windows use a similar system so check with auto body part suppliers and auto window suppliers............
madjack 8)
Postby Elumia » Fri Nov 10, 2006 11:13 am
I beleive Airstreams used Hehr windows. You might want to check on the Airstream forums. http://www.airstreamforums.com I know I have seen a vintage trailer site that also had some parts, but I don't have those favorites on this puter.
Mark
Elumia
Images: 15
Postby Spadinator » Fri Nov 10, 2006 3:55 pm
Thanks guys..I'll check those idea out.
Here is the window itself:
And here is the clip...it is supposed to have ridges along the outside but those are worn off. The window falls out rather that sliding.
Sorry the pics are so bad.....you can sort of see the ridges on the clip.
Spadinator
Images: 47
Postby Micro469 » Fri Nov 10, 2006 11:35 pm
Spadinator wrote:Thanks guys..I'll check those idea out.
Are the clips missing the ridges from both sides? Can you flip/turn the clips around so the other/back/left/right side is on the front? maybe the ridges aren't worn completly on both sides.....
John
Micro469
Images: 382
Postby Elumia » Sat Nov 11, 2006 12:37 am
any of these the right thingy?
http://www.vintagetrailersupply.com/Sea ... asp?Cat=27
Mark
Elumia
Images: 15
Postby Spadinator » Sat Nov 11, 2006 2:49 am
Those clips look similar but mine are plastic and it's hard to tell how big they are. I know my photos don't give a good idea how little mine are. The ridges on the clips are on the edges and they are glued to the frame. I can only guess they are worn out becasue the window just falls out. Also the fuzzy weather stripping on the window is also gone.
I am beginning to think that I may have to use the glass and make a hopper style window with a wood frame.
Spadinator
Images: 47
Postby Rick Sheerin » Sat Nov 11, 2006 6:55 am
Spad-Try www.blainewindow.com They have a 195 page catalog of nothing but window parts. They even have a research dept. to locate hard to find parts.
Rick S
1996 Casita Spirit Deluxe 17ft
Careful with that Axe, Eugene
Rick Sheerin
Images: 100
Postby Spadinator » Sat Nov 11, 2006 7:47 am
Thanks Rick.....I have requested a catalog!! :thumbsup:
Spadinator
Images: 47
Postby Laredo » Sat Nov 11, 2006 5:04 pm
if all else fails you can "build up" Lexan (you'll need a flat and some split dowels, and probably a lot of sandpaper) from a place like this:
http://www.modernplastics.com/lexan.html
Laredo
Postby KA » Sat Nov 11, 2006 10:00 pm
Hi Spadinator,
You can check your local window supply shop. Also, you could call an RV salvage place and see if they have any parts.
Singleton's RV in Rochester, Washington has a bunch of bins with all sorts of used window parts. Their phone number is 360 273-9566.
Good luck!
Kris
KA
Images: 9
Postby Spadinator » Mon Nov 13, 2006 1:32 pm
Well I struck out today.....I checked all the RV shops and glass shops. I actually found the clip in a book at Northern Utah Glass but when we tried to order it.........DISCONTINUED!!!!! :x Hopefully that catalog will have it.
Spadinator
Images: 47
