I've got a #3500 Flexride on the new frame, with electric brakes. I figured out that there is a left and right brake assembly. Which way is up? Coil on the bottom or top?
It's painted, ready for the hubs..I'm confused!
halfdome, Danny wrote:On my Dexter electric brakes the magnet is on the bottom. I did a searchand found that is typical. Danny
Nitetimes wrote:The magnet should be on the bottom and pull towards the rear. The magnet arm will be in front.
Dale M. wrote:Nitetimes wrote:The magnet should be on the bottom and pull towards the rear. The magnet arm will be in front.
Quite true... BUT...
IF you have correct brake on each side, position is not absolute... IT will function no matter where magnet is located...
Dale
Nitetimes wrote:
They will work in any position, but, they will work their best in their proper position.
Andrew wrote:Don't be showing your hand (parking) brakes to these
Merkans, they'll be getting all jealous - in theory, they can be bought in the
US, but no-one's ever had them, so far as I've seen.
