Brakes what type
What type of brake do you use on trailer
Disc
1
3%
drum
5
17%
Brakes ?? none why
23
77%
anchor or ripcord.
1
3%
Total votes : 30
Brakes what type
Postby Ron Dickey » Sun Mar 27, 2005 10:49 pm
what you got down there??
121377......134179
Ron Dickey
Images: 711
Postby Nitetimes » Mon Mar 28, 2005 1:11 am
I think brakes are pretty much a preference thing unless you are pulling with a very light vehicle. In which case they are a pretty good idea.
Most trailer brakes are electric drum brakes, there is also a hydraulic actuated coupler for a hydraulic setup, more pricey than electric and not my personal favorite, mostly because you loose a little of the control you have with an electric brake controller. Disc brakes are showing up more on trailers now but they can be pretty expensive, I'd use them but they are a bit out of my price range.
On my TD there won't be any brakes, mostly because I will be sure that whatever I tow with has enough brake to stop me and the trailer.
I'm sure everyone will have some thought on this subject and this is just my .02 worth.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby JunkMan » Mon Mar 28, 2005 10:35 am
I plan on keeping my trailer weight low (under 900 pounds loaded), so don't think I'll need any brakes. The car has 4 wheel discs, so there shouldn't be any problem stopping.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby len19070 » Sat Apr 09, 2005 5:15 pm
Breaks or no brakes is really a common sense question. I have a Dodge Dakota 4X4 Quad Cab. This is the only thing I tow my trailer with. The brakes on this vehicle are more than adequate to stop a 725lb trailer. But...if you drive a Mazda Miata and try to tow....Look into some trailer breaks!
Happy Trails
Len
len19070
Images: 24
Postby Geron » Sat Apr 09, 2005 7:12 pm
I pulled the Aliner w/o brakes a few times. Ended up putting brakes on myself. I feel much safer. The TD - no brakes. Don't feel they're necesary with such a light weight. Never looked into putting brakes on the HF axle. Would have to have different hubs and don't know about the space available for the drums. Nope. No breaks for the TD.
Geron
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Return to User Polls
