Anybody using or considering an inverter when shore power isn't available?
If you considered it, but opted not to use one, was it because you went with a generator instead?
Nitetimes wrote:My travel tailer is setup up so a battery charger runs off the inverter and charges the battery at the same time it is being used, all the lights are 12v. Seems to work. The A/C and microwave are only functional with shore power tho.
Dean in Eureka, CA wrote:Nitetimes wrote:My travel tailer is setup up so a battery charger runs off the inverter and charges the battery at the same time it is being used, all the lights are 12v. Seems to work. The A/C and microwave are only functional with shore power tho.
Like I say... I'm a putz when it comes to electricity.
OK... Your inverter runs the battery charger, which charges the battery, which runs the inverter.... That sounds like an endless loop. I don't see how you could gain on the charge of the battery unless you bring some shore power into the mix.
Dean in Eureka, CA wrote:I was wondering (Remember I'm a putz when it comes to electricity) if a short jumper cable with male plugs on each end could be used to plug into one of the outlets in the shoreline circuit to feed other outlets when shore power isn't available, or is there a better way to go about this?
