Does anyone know what will dissolve lithium grease?
Postby Joseph » Fri Apr 22, 2005 11:55 am
I used blue lithium grease on my HF bearings and can no longer get the same stuff. I'd like to switch to a synthetic grease but I understand it's a bad idea to mix lubricants as they can work against each other and break down. Basically, I need to clean the old lithium grease out of my bearings but to my surprise acetone doesn't cut the stuff. Anybody know what does?
Thanks,
Joseph
Joseph
Teardrop Pirate
Postby Nitetimes » Fri Apr 22, 2005 12:08 pm
lacquer thinner
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby nickster60 » Fri Apr 22, 2005 9:20 pm
parts cleaner, I think kerosene will also do the job
nick
nickster60
Postby MikeR » Sat Apr 23, 2005 1:03 am
Gasoline will too but it's expensive!
MikeR
Postby Joseph » Sat Apr 23, 2005 1:07 pm
MikeR wrote:Gasoline will too but it's expensive!
I don't know why I thought I'd used lithium grease. :thinking: When I pulled the canister out of the grease gun it was plain old general purpose grease. But in any case, gasoline did the trick. :thumbsup:
Thanks,
Joseph
Joseph
Teardrop Pirate
Postby steve wolverton » Sat Apr 23, 2005 10:38 pm
Joseph wrote:But in any case, gasoline did the trick.
Gasoline is a miracle liquid. It does everything, and you can sniff it. :?
�veni, vidi, vici.�
steve wolverton
Images: 11
Grease
Postby OkieSailor » Sat Apr 23, 2005 10:53 pm
Next time try WD-40. Even on old caked grease zips right off, also good on road tar on the teardrop. Spray and lightly rub.
Yes OkieSailor is an Oxymoron!!
OkieSailor
