I use a 12v demand and a sink sprayer nozzle to get much more water pressure. My setup allows me to recirculate the water in a 7 gallon plastic jerry can. That way I bring the water up to tempurature before showering. I can then turn the water on and off without having to worry about having flow through the heater unit.
S. Heisley wrote:There's something I don't understand: What happens to the used water when you're showering? Do you just let it run out onto the ground or do you catch it in a tub or....?
