steve wolverton wrote:I'll work on a FAQ for this stuff and try to get it posted in the near future.
Wimperdink wrote:I'm lazy so what I'll probably do is make a removeable panel in the floor that when removed leaves an empty hole to the ground. Then in the hole goes a frame with canvas draped down to a floor that just lays on the ground with a carpeted inside. It would give full stand up capabilities without having it hang down during travel and make the build process that much easier. Canvas sides would make it so you can just fold it up and slide it under the bed when not in use.
Wimperdink wrote:If I steal too much of your design, I'll print a small Steve Wolverton icon on a piece of rice paper and epoxy it into a cabinet.
steve wolverton wrote:I just weighed the camper. I only have a couple more trim pieces to put on, window, and dropped floor.
Total weight: 619.5
Door side tire: 240.5
Port side tire: 236.5
Tongue: 142.5
No doubt I'll come in under my 650 goal!
