This is an adaptation of Mike’s Winter Warrior with inspiration from Rayvillian's (Gary & Trudy) weekend warrior . It is based on A TSC 4X8 No floor trailer frame, 76” wide and 120 “ inches long with a headroom of 74” from the floor when the hatch is fully extended
Hatch up
Door (removed for clarity)
Upper portion of Door removed for detail
Door up (hatch removed for clarity)
Door folded down (hatch removed for clarity)
Now for the fun part – gathering of ideas for seals and hinges. I do plan to fully insulate the cabin and build as light as possible. The goal is to be able to garage this little gem and come in under 1300 lbs so the height is a factor when collapsed. What do you Think?
