Side Mount table question
Postby bobhenry » Sat Jul 18, 2009 4:12 am
Kenny :( That's it ! That's all I get
I expected the full engineering analysis. Non slip foot , click and slip adjustment , padded shelf rest which is also non slip , handy carrying handle in the middle and ultra light aluminum design.
Hell I thought it was brilliant and if I meet a "little person" on the trail with a turned ankle I can loan it out. :lol: :lol: :lol:
Images: 2617
Postby kennyrayandersen » Sat Jul 18, 2009 11:20 pm
Easy now. Here is the engineering (practical) prospective. I've seen some pretty fat bastardes using those (Myself included! :lol: ). So, we have a special category called GBI -- Good By Inspection -- no numbers needed on that one! :thumbsup:
We also have NDG -- No Darn Good (or the other version, which I'll let you extrapolate!)
kennyrayandersen
Images: 38
Postby bobhenry » Sun Jul 19, 2009 4:45 am
:lol: :lol: :lol: :lol:
Images: 2617
Postby Barry J » Sun Jul 19, 2009 7:40 am
with the round edge up won't water get behind the bracket?
Barry J
Images: 22
Postby kennyrayandersen » Sun Jul 19, 2009 5:24 pm
Barry J wrote:with the round edge up won't water get behind the bracket?
Yes, but it will run off the front or back while stationary and especially the back while going down the road. Even when the flat is up water will still get behind the extrusion. I would probably wet-install it [with some kind of sealant] either way.
kennyrayandersen
Images: 38
Postby Nobody » Mon Jul 20, 2009 8:32 am
If you've got a wood wall, water behind the rail might be a problem (guess it'll depend on your finish). On my aluminum sided TD I just followed Madjack's practice & after initial installation I simply removed the screws (one at a time) & placed a 'dab' of sealant (Sika-flex[?]) in each screw hole then reset the screws. It ain't leaked yet 8)
Harvey -
Nobody
Images: 342
Postby aggie79 » Mon Jul 20, 2009 10:41 am
I guess you use a spacers, maybe nylon washers, at the screw locations to create a space between the bracket and the sidewall of the teardrop so it will drain. This is similar to what you do to attach a ledger board to a house for a wood deck.
Postby kennyrayandersen » Mon Jul 20, 2009 11:14 pm
aggie79 wrote:I guess you use a spacers, maybe nylon washers, at the screw locations to create a space between the bracket and the sidewall of the teardrop so it will drain. This is similar to what you do to attach a ledger board to a house for a wood deck.
Personally, if you install with a sealant like Sikaflex you should be fine. Not that I think it's necessarily a problem, but the washers could, unless they're big'uns decrease your foot print a bit. I don't think if I has a woody I would install a aluminum extrusion in the side -- somehow that might throw off the overall effect!
kennyrayandersen
Images: 38
Re: Side Mount table question
Postby MontanaTeardrops » Sat Aug 17, 2013 12:05 pm
I would like to put a table like that on my Teardrop also. Do they have those brackets at Home Depot?
MontanaTeardrops
Postby godskid » Tue Aug 20, 2013 11:28 am
MontanaTeardrops wrote:I would like to put a table like that on my Teardrop also. Do they have those brackets at Home Depot?
No, this is a specialty sort of item. There is a link in one of the posts on page two -- two of us bought this bracket at dyersonline.com That was a few years ago, but they probably still have it.
godskid
Images: 10
Postby MontanaTeardrops » Tue Aug 27, 2013 6:23 pm
This is how I mounted mine.
MontanaTeardrops
Postby working on it » Tue Aug 27, 2013 7:20 pm
Here's a link to alternative table ideas: http://www.tnttt.com/viewtopic.php?f=2&t=56156&hilit=side+table
173193172890148599
working on it
Images: 457
Users browsing this forum: Google [Bot] and 8 guests
