Step 3: Build the floor
Here is a generic building plan for a teardrop designed by the members of T&TTT.
Postby SteveH » Wed Oct 26, 2005 5:36 pm
Vega,
Check out my gallery...I built at 60" wide on top of a 60" trailer frame AND covered the frame with the side sheet aluminum. I designed it that way from the get-go to get the max space inside, not go over 60", and cover the frame.
So far, it has worked out great with no problems.
SteveH
SteveH
Images: 42
Postby Vegabond9 » Wed Oct 26, 2005 7:28 pm
Steve, you built just about what I want in my TD. I really don't want two doors and I love the windows. Where did you get them?
Vegabond9
roof tar
Postby backwoodsman » Mon Oct 31, 2005 8:09 pm
mikeschn wrote:
Use roof tar to coat the underside of the floor, making sure not to get any tar on the sides where the walls will be attached.
Roof Tar! Roof Tar?
What kind of roof tar?
I went to the hardware store and they recommended
204 Plastic Roof Cement made by Henry Company
http://www.henry.com/Patching_Repair_Cements.175.0.html
Will this work?
What did you use?
G
You don't know what you don't know!
backwoodsman
Images: 35
Postby stjohn » Mon Oct 31, 2005 8:17 pm
This is what I used could not find what everybody else used they said it was the same thing Was really eeasy to work with got it at tractor supply
Mike
Only he who attempts the ridiculous
Can achieve the impossible
stjohn
Images: 68
Postby SteveH » Mon Oct 31, 2005 10:09 pm
Vagabond9,
I got my windows here: http://www.tjtrailers.com/store/product10238.html
They are the 15" X 24" size. They are actually designed to go horizontal, but I wanted them vertical to put the opening lower on the trailer so the breeze would hit me more when laying down. You do have to drill some new weep holes if you mount them vertically or they will leak water.
SteveH
SteveH
Images: 42
Postby madjack » Mon Oct 31, 2005 10:24 pm
Greg...that may be a little heavy bodied...the link states that it is TROWEL grade...it would probably work but you should try and find something a little more "liquiddy" or "brush/roller" grade...that stuff may be more like tryin' to drink the corn mash instead of the drippin's :D
madjack 8)
p.s. we used MinWax ClearShield a heavy bodied polyurethane that is UV protected and outdoor rated...it is expensive but we had it left over from a previous job
Postby stjohn » Mon Oct 31, 2005 10:30 pm
Did somebody mention honeydew vine water :tipsy:
stjohn
Images: 68
Return to Generic Building Plans
