laminate floor
laminate floor
Postby hberg » Sat Oct 16, 2010 8:34 pm
Has anyone put in a laminate floor? What do you think are the pros and cons? It seems pretty simple in a cargo trailer...much easier than described here. http://www.modmyrv.com/2008/08/05/rv-laminate-flooring
hberg
Postby jwhite » Sat Oct 16, 2010 8:55 pm
I am going to install this in my house and will buy extra to go in my trailer.
I was going to install it in my trailer but I already had some stick down flooring,and it looks great but it has already started to come up after just a few months.
jwhite
Images: 46
Postby tk » Sat Oct 16, 2010 10:26 pm
It works great in an RV, but assuming you are building a traditional TD, why use it at all since the whole floor will be covered by a mattress? Why add the weight when so little will be seen? Vinyl flooring makes more sense.
Best,
Escape to Missouri
tk
Postby tk » Sat Oct 16, 2010 10:29 pm
Sorry, didn"t read closely re. cargo trailer. Still, same sentiments, vinyl if weight is an issue.
Escape to Missouri
tk
Postby High Desert » Sun Oct 17, 2010 1:41 am
Sounds like a good idea for a CT. It's tough stuff and looks great. You can use the thinner less expensive type to save some weight. Just make sure and leave a slight gap around the edges as it does expand and contract a bit with temp changes.
Shaun
High Desert
Images: 27
Postby dudleydoright » Sun Oct 31, 2010 2:51 pm
please keep in mind laminate will buckle and warp if it gets wet below the protected surface.
GONE FISHIN'
ddr
dudleydoright
Postby MikeW » Sun Oct 31, 2010 5:25 pm
Laminate is used a lot in commercial RVs with good results. Although it is generally glued down to the floor rather than installed as a floating floor. I think a laminate floor gives a nice touch over linoleum.
MikeW
Postby pete42 » Sun Oct 31, 2010 6:45 pm
I know of several that have done it I just saw one last week.
pete42
Postby dudleydoright » Mon Nov 01, 2010 10:39 am
laminate is not designed to be glued to the floor because it must be able to expand and contract due to temperature and humidity changes, else it will peak at the seams.
GONE FISHIN'
ddr
dudleydoright
Postby hberg » Mon Nov 01, 2010 10:53 am
Thanks for all the good advice.
After reading your responses and talking to the sales people I went with vinyl plank flooring. The laminate can't get wet or the connections go bad. The vinyl plank went down super easy on my rectangular surface, and was just as cheap by the time you buy underlayment for the laminate. Thought about vinyl sheets, but for seven feet of with and it gets sold in 6 or 12 foot widths it didn't make sense.
hberg
