Baby canned ham design
Canned Hams of all types and sizes...and Bread Boxes to go with that ham......
Postby angib » Tue Dec 28, 2010 10:44 am
Here is the smallest canned ham design, the Wanderer, that can be built on a HF utility trailer. It's low enough to fit in some garages, but has 72" headroom over the dropped footwell.
This layout provides a 54" bed/dinette, (tight) space for a galley and room for a portapotty:
For hunter's use, where two separate beds are more useful, there is this version:
Wanderer PDF
Let's see if there's any interest in this design.
angib
5000 Club
5000 Club
Images: 231
Postby steve smoot » Tue Dec 28, 2010 10:49 am
I really like the Hunters version, Andrew. :thumbsup:
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby beverlyt » Tue Dec 28, 2010 11:21 am
I really like this trailer. Lots fitted in to a small space:)
Bev
beverlyt
Images: 20
Postby aggie79 » Tue Dec 28, 2010 11:32 am
Andrew,
That is a very nice design and profile - compact, attractive, and well-fitted.
Donutboy's Retro-Kamper is similar in layout, perhaps longer, although the profile is different.
http://www.mikenchell.com/forums/viewtopic.php?p=610860
Postby hotrod » Tue Dec 28, 2010 12:29 pm
nice!! maybe a new camper is in my future after all.. :thinking:
Paul
hotrod
TILT
TILT
Postby mikeschn » Tue Dec 28, 2010 2:52 pm
Good job Andrew,
That is a really compact design with all the comforts of home.
At first blush I would add 4" in the porta potty area, and 3" in the galley area.
But then again, maybe just take 7" off the bed.
But I gotta hand it to you, you got it all into 96". That alone is pretty impressive!
Images: 479
Postby S. Heisley » Tue Dec 28, 2010 9:38 pm
Well done, Andrew! :applause:
Questions:
I noticed that you moved the axle back. Did you do that simply to make room for the door and not for any weight issues?
Using a sandwich-style of building, how much do you think something like that would weigh, at the minimum?
Postby Prem » Tue Dec 28, 2010 9:55 pm
:applause: Really a fine design Andrew! :thumbsup:
Prem
My goal...
...is to live in a trailer.
Prem
Images: 144
Re: Baby canned ham design
Postby gullywompr » Tue Dec 28, 2010 11:31 pm
angib wrote:Let's see if there's any interest in this design.
Yes, there is.
Cheers,
Curtis Olson
gullywompr
Images: 7
trailer size
Postby danlott » Wed Dec 29, 2010 2:51 am
Andrew,
Which trailer frame did you plan this to fit on? If it is the 4x8 trailer you would have to cut it down.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby Wimperdink » Wed Dec 29, 2010 2:55 am
:thumbsup: :thumbsup: :thumbsup: :thumbsup:
Wimperdink
Images: 33
Re: trailer size
Postby mikeschn » Wed Dec 29, 2010 5:51 am
danlott wrote:Andrew,
Dan
HF to the rescue!
Images: 479
Postby angib » Wed Dec 29, 2010 6:29 am
Assorted responses:
The idea was to use a standard 4x8 HF trailer because everyone can get one of those. The 5x8 would be much better but it costs twice as much, plus so much of it is then thrown away.
The last 12" of the trailer frame (and the last cross member) is cut off to give a 7ft trailer with the axle well back, but the axle is still in its original place. This needs only cutting and drilling, not welding, so I think most people would be happy to do that. I don't think the welders on the forum recognize how much of a barrier welding is to the non-welders!
I will experiment with a longer body on the original frame but then a new tongue will be required as lengthening the HF tongue isn't practical with a dropped footwell.
This is the same layout as the Lil Guy in the Vintage Plans. Back then they used a 48" bed, a 30" gap and 18" deep cabinets. But I reckoned with modern people sizes a wider bed was more important than good cabinets (plus I've used a double-skin roof), so this one is 54" bed, 24" gap and 15" deep cabinets. If it was for mainly solo use, a narrower bed and deeper cabinets ( 48/27/18 ) would be better.
There are two 'bumps' above the floor at the front and back. These are my preferred way of supporting the overhanging body without going the more popular method of throwing lots of heavy framing under the floor - these are two 1x6 boards on edge sitting on top of the HF frame and holding up the sidewalls. 1x4 might be enough, I'm not sure. Either has the problem that they will create a 'nook and cranny' behind which things will get dropped and lost!
I would hope for a finished weight under 1000 pounds, though that does mean building light (which some folk just can't do) and not using the space to fit lots of heavy stuff. In reality, this is a very small trailer which is not that apparent from the layout, so there isn't much opportunity to add too much stuff. For example, if a fridge is wanted then it has to be instead of the portapotty. This is really just a teardrop with enough height to put your pants on standing up.
There is a bit of Steve Wolverton's Puffin mixed into the design as well - I propose to use his single skin with insulation and fabric covering technique for the sidewalls. But the main inspirations were from the Vintage Plans and my copies of two of the designs are called Wander Pup and Wander Bug, so that's where the Wanderer name came from - I know names matter to some folks....
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Wed Dec 29, 2010 8:12 am
Andrew,
If you send me the model, I can do up a rendering for you.
Images: 479
Postby angib » Sun Jan 02, 2011 11:47 am
I am slowly getting on with the detail of this design, but I am plagued with ideas for different internal layouts. Most I reject but this one seems like it might suit some folks:
The foot of the two beds do rather get in each other's way, but then this is a small trailer.
Updated Wanderer PDF
angib
5000 Club
5000 Club
Images: 231
Return to Canned Hams & Bread Loaves
