myoung wrote:The fridge was a big disappointment. It is one of those absorption types that runs on AC, DC, or gas. I didn't have the opportunity to test the AC mode, but the DC mode consumes too much juice for the paltry amount of cooling gained. The gas mode was just as disappointing. It's hard to tell whether the flame is lit and what you can see is miniscule. Gas and electricity work beautifully on our Airstream but that has a real fridge not one of these pretenders.
cracker39 wrote: I like that propane tank "cage". Where did you get it? And, can you tell me exactly what connections you have to connect the tank to your cook top unit? I have a two burner Wedgewppd Vision that I haven't installed yet and have no idea where or how to get the hoses with the right connectors. I suppose I'll go to one of the RV dealers around Lakeland.
S. Heisley wrote:Mike, your trailer is very professional and good looking. Congratulations on your maiden voyage with her.
Woodstramp wrote:Myoung, Outstanding work! Love the roof hatch thing. Looks really good. When you going to start #2?
Where did you get the drip rail that you mounted over the door?
myoung wrote:Frank,
Thanks for your comments about the fridge. This one performs worse than the 3-way Dometic in my 1990 VW Westfalia.
The model is Dometic RM 4223 Americana. It does not have a freezer compartment, just a fridge. The ignition is piezoelectric manual. I did get reasonable cooling overnight in our garage with AC, but still not up to my hopes and expectations. Cooling below 20 degrees from ambient air temp seems to be the limit, but even that didn't happen while camped in mid-60s daytime temps and night time lows down into the high 30s.
I set the thermostat to the coldest setting, number 5.
Any suggestions would most welcome. Thanks.
