Installing fixed windows
Postby greasywheats » Fri Feb 10, 2006 1:39 pm
I am at the design stage looking to incorporate a single oval window in my TD in approximately the same location as the Camp-Inn windows on the front curve (my profile is almost exactly like the CI profile, to give you an idea of the curve there). Do any of the window afficionados here have any comments on using the method by 48Rob for my application. Being on a convex surface, will the force of a piece of 3/16" lexan/plexiglas be too much for the window seal to remain water tight? I am not familiar with glass/rubber sealants, but I'm guessing that there are some pretty heavy-duty sealants that you could put in the window seal channel to lock the glass in place. :thinking: I read the post about how Camp-Inn does their windows, but I'm a novice, so I didn't really get it. I'd really like to pursue a front window, so any other ideas would be welcome! :thumbsup:
Thanks!
greasywheats
Images: 25
Postby Cary Winch » Fri Feb 10, 2006 2:49 pm
The method Rob shows is basically the same as we do on our Raindrop. The exception being that rather than solid plwood it is thin paneling and a sheet of aluminum outer skin sandwiched there.
Beetle side windows use a different gasket actually that is meant for a formed opening in the sheetmetal. That is the style that we use on our 550 front windows. That is why they have a nice flush look to the gasketing. But of course that requires the skin to be formed in like on a beetle. That is what we do on ours.
Greasy wheats, if you profile is similiar to ours you should be able to use the flat 3/16 Acrylic and it will flex enough. The radius is large enough that the gasket will compensate. Now, our front Raindrop quarter windows have a smaller radius and we form those in a oven first. But the larger front picture window is in a body curve with a larger radius and we don't need to.
The problem with using Rob's method on a front window is mainly how to trim out the window opening inside decently. Your have to have a thin section of roof in that area. I know one guy who did a oval in his and it didn't work out too good because the aluminum alone wouldn't hold it's shape and did some wierd stuff. This would mean you can't just attach to the aluminum but would need to sandwich to a plywood paneling or something with that glued to a structure close to the window.
Cary
Cary Winch
Teardrop Manufacturer
Postby greasywheats » Fri Feb 10, 2006 3:14 pm
Cary- thanks! Took some re-reading there, but i think i understand now... So the problem is that you need to provide a solid "frame" (approx. 3/4") for the gasket to be seated on, in a section of the roof where the curve is made by bending the outer aluminum/plywood skin and thin inner plywood/beadboard ceiling. So there is no substantial framing there to hold the gasket all the way around the opening (and maintain the front radius).... :?
greasywheats
Images: 25
Postby Cary Winch » Fri Feb 10, 2006 3:58 pm
That is pretty much the idea, there needs to be some support or after the hole in the aluminum is cut it will flare out. Though making it 3/4" thick there might not be the solution. That style of gasket is very common but not for thick wall like Rob used. 3/16" is more likely what you will find. That is what we used on the Raindrop, go to this page and look at pictures of it and you will see how we made a framed opening inside to allow for this:
http://tinycamper.com/topsecret
Pictures 22-26 kind of show the inside and picture 4 shows the outside of a window.
Cary
Cary Winch
Postby MikeDrz » Fri Feb 10, 2006 4:06 pm
so you would have to work the aluminum around the corner into the window opening?
Cary Winch wrote:That is pretty much the idea, there needs to be some support or after the hole in the aluminum is cut it will flare out. Though making it 3/4" thick there might not be the solution. That style of gasket is very common but not for thick wall like Rob used. 3/16" is more likely what you will find. That is what we used on the Raindrop, go to this page and look at pictures of it and you will see how we made a framed opening inside to allow for this:
Cary
Michael Drzewiecki
Teardrop Dreamer - Cargo Converter
Click here to check out Cargo Conversions...its hip to be Square!!!
MikeDrz
Postby JunkMan » Fri Feb 10, 2006 5:11 pm
48Rob wrote: Can you tell I'm not a Volkswagen man :oops:
Rob
I've got several of them, including a "Thing" which I hope to get restored, and possibly build a "weekender" style TD to pull behind it.
We had a heck of a time finding a set of the pop out type windows for my wifes 1956 bug, but I probably have some of the fixed windows laying around if anyone is thinking about trying some.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby angib » Fri Feb 10, 2006 6:14 pm
Rob,
Fitting that rubber section looks like hard work! I've only done a rubber into a thinner wall, so the rubber could go on the window first and then both of them get fitted in the body. This means you can just wind a piece of string all round, laid into the body groove - when the window is fitted, pulling on the string rolls the lip in over the body opening. Did that make sense?
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Cary Winch » Fri Feb 10, 2006 6:39 pm
Michael,
That is exactly the idea. We have a large heavy forming block that the roof skin gets clamped to. The window opening is already cut out. It then gets hand hammered around the former and trimmed flush on the inside edge. The preformed skins then get installed on the roof which also has some structure in place to locate the formed edges.
Andrew,
You got it right on, we use a piece of small gauge wire to do the trick. The window gasket Rob used is a two piece which is easier to pop in than a one piece but then you have the fun of installing the lock strip. Fortunetely there is a simple tool for making that easier.
Cary
Cary Winch
Postby 48Rob » Fri Feb 10, 2006 7:04 pm
Andrew,
The first one was, but then it got easier.
Getting the glass cut small enough to have just a little "extra" working room makes a big difference.
After cutting out the template, I set my dividers to just over a 1/4" and then trimmed that off too.
Lots of soap made a big difference between easy and hard.
I put off the window job for several months as I was intimidated by the lack of flexibility of the rubber channel, and the fact I'd never done it before.
After a while though, I got to wondering how I could build a tear, and all the other things I've ever built, and be afraid of a piece of rubber :thinking:
In the end, I won!! :applause: :applause:
Took about an hour per window including prep, cleanup, and re hanging the blinds.
Rob
48Rob
Postby Cary Winch » Fri Feb 10, 2006 8:05 pm
Rob,
Bravo, those sure did turn out good though.
Cary
Cary Winch
Postby greasywheats » Sun Feb 12, 2006 12:43 pm
Thanks for the replies everyone (especially for 48Rob's post with Pics and Cary's input). Figuring out a front window was my last big task left, and everything here has been so helpful. Now I just hafta get it built. :worship: Thanks Again!! :applause:
greasywheats
Images: 25
Postby PaulC » Sun Feb 12, 2006 2:38 pm
MikeDrz wrote:the beetle came to the US in 1949, was first made in 1945 in germany.
I may be wrong here but my history book shows the first "peoples car"(VW) was built in the 30's. As a side note, it was originally designed by Ferdinand Porsche. Same bloke who designed and built Porsche cars.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Kevin A » Sun Feb 12, 2006 2:44 pm
Cheers
Paul :thumbsup:
Right you are, Paul,
http://people.westminstercollege.edu/st ... istory.htm :thumbsup:
Kevin A
The other guy
Images: 289
Postby greasywheats » Wed Feb 15, 2006 6:17 pm
Hey 48Rob- I am going to be doing a front window on my TD...Thanks for the instructions... I am going to get my gasket from Austin HW as well. I am looking at AS 1706 for a body panel 719" to .782". Is this the gasket you used? If so, do you have leftovers (I see they sell in 50' minimum rolls). If you have 10' extra, I would be interested in buying some from you if you have a bunch extra. :worship: This stuff isn't cheap! Let me know.
Thanks!
greasywheats
Images: 25
Postby Cary Winch » Wed Feb 15, 2006 6:56 pm
Greasywheats,
Hey, by the way. Kind of off subject but we have a couple of units landing in the Portland area later this week. In case you are interested in looking at one of ours, at least to peek at front windows, I am sure one of the customers would let you see it. One is going right to Portland, the other to Seaside.
Cary
Cary Winch
