GPW wrote:Here's just an idea ...
swampjeep wrote:eagle, If he is talking a conventional "truck camper", they are not built as part of teh truck, just built to go in the bed of a pick-up truck
here is something as an example, shown both in the truck, and off, they would have some type of straps holdign them to the truck normally
Conedodger wrote:swampjeep wrote:eagle, If he is talking a conventional "truck camper", they are not built as part of teh truck, just built to go in the bed of a pick-up truck
Not far out, but here is 2 pictures on a truck the same as mine
And mine will be lower so i can put it in my garage (7 foot high door) and have a lift up roof with solid walls made of foam.
Its a bit like taking a 8' x 6' Tiny Trailer and taking the chassis off and that was the reason i can here as you guys seem to be able to do amazing things in a small footprint.
For those interested my truck is featured http://landcruiserparts.co.uk/toyota/index.php?option=com_content&view=article&id=19&Itemid=14 but nothing about the camper part yet as its still in the planing stage.
[/url]
swampjeep wrote:hmm, so you're looking at a bed camper (non-cab over) that will have a hard side (possibly foam) pop top. I do see a concern here as teh foam construction method relies on tying in to teh floor and walls for its strenth. With a pop-up style you will lose that tie in. I'll have to think on this one a bit.
Conedodger wrote:Just pressed submit and had a thought.
Maybe i will make a unit in cloth / pva and if it does not work, bolt it to a trailer and sell it and make another. I am sure just like eagle you learn a lot in your first build.
Conedodger wrote:I dont think holding it down or a foam pop to will be a problem if i do it in glass fiber and epoxy, its just dare i do it in T2.
I think i am convinced foam will be perfect for it so maybe i will cover some of it in cloth / pva and if it does not work strip it and cover it all in epoxy.
Thanks for all your ideas
