Great Writeup on Fiberglass over Foam
Postby stomperxj » Mon May 16, 2011 10:46 am
Great writeup on a 'glass over foam trailer.
http://www.goldbrand.info/motorcykelhusvagn2.html
stomperxj
Postby GPW » Mon May 16, 2011 10:59 am
Stomp, pretty amazing !! Thanks !!! 8)
Postby Volund » Mon May 16, 2011 11:45 am
wow, now if only I had any skill with fiberglass and resin, that looks like an awesome low weight solution.
wonder how it will hold up over time.... and what the total weight is?
Volund
Postby eaglesdare » Mon May 16, 2011 11:53 am
wow, that came out nice. love the way they shaped the foam. thanks for that link. :applause:
Louella
May the foam be with you.
eaglesdare
Postby stomperxj » Mon May 16, 2011 12:19 pm
Volund wrote:...and what the total weight is?
319lbs according to the text at the top of the page...
stomperxj
Postby Volund » Mon May 16, 2011 12:33 pm
yeah, apparently I can't read....
Thanks :thumbsup:
Foam and fiberglass looks like an awesome solution for a small car.... like my Rabbit
Volund
Postby swampjeep » Mon May 16, 2011 1:46 pm
Thanks :thumbsup:
heck, I think my jeep is 2x the power and weight of a rabbit, but I think teh foam build will be a good route for me.
swampjeep
Postby Volund » Mon May 16, 2011 8:20 pm
swampjeep wrote:heck, I think my jeep is 2x the power and weight of a rabbit, but I think teh foam build will be a good route for me.
Yeah, if nothing else it should help with gas mileage.
Thinking about it, I wonder how a foam tear would hold up in high winds.... you have the same side surface area as a normal trailer (depending on what profile you use), but with significantly less weight. :thinking:
Volund
Postby Wobbly Wheels » Wed May 18, 2011 2:16 pm
Thanks Stomper , this is exactly what I was looking for !
I am working out a glass-over-foam popup a la the Compact design (with a few twists of course...).
That post was just what I'm looking to do, right down to the same resin used, lol. will also be running the shell right up the bridle, but it'll be interior space rather covered exterior storage - that will probably be the head.
Part of foam's appeal for me is that I can keep the suspension loads light enough to drag it through cross ditches and waterbars and still be able to pull it up a chattering washboard with my 4 cyl truck. How have you found yours to be as far as stiffness and robustness on rough roads (even though yours isn't foam)?
Did you have to make a compromise on Sawtooth between ground clearance and ease of access or do you just use as a step to get in and out after building it to the same height as your XJ?
Wobbly Wheels
Postby stomperxj » Wed May 18, 2011 3:16 pm
Wobbly Wheels wrote:Thanks Stomper , this is exactly what I was looking for !
My trailer has held up great. No stress cracks or anything at all. I think the shock/spring combo really helps tone the bumps down too. The ground clearance is a little high... I have to kinda stretch up to get my butt in the door but its not bad. My GF Nicole has to have a little yellow foldy step to get in though but she's only 5'-2". The next trailer will be a spring under design to lower the chassis some but the main reason is so I can gain more height as the next trailer will be a lot bigger than this one...
stomperxj
Postby mikeschn » Sat Jun 11, 2011 9:35 am
Can anyone venture a guess as to what weight this fiberglass is?
Images: 479
Postby GPW » Sat Jun 11, 2011 9:54 am
Mike , just a WAG looking at the weave , the tape he's putting on the edges appears to be the same stuff I used (common)... the glass on the stiffeners looks Much heavier , coarser.. and by looking at those edges appears it was cut from a larger cloth ... Probably not too critical because you can always add another layer or too when in doubt ...
Postby Wobbly Wheels » Sat Jun 11, 2011 11:24 am
Mike, I'll stake my reputation as an armchair/internet expert on that being 6 oz cloth.
It's the most common for epoxy sheathing and you can see the corner through the sheet he's holding up.
I'm looking to buy a roll of it for my build - I normally use a fair bit of it for my side jobs but not enough to justify a bulk purchase. My build is going to suck up quite a bit though and, despite building on a budget, I don't want to compromise on adding glass weight where needed because I don't have enough on hand...good thing it keeps forever...
BTW, I like how he's beveled the edges of the skirting - I may steal that rather than rounding them over....
Wobbly Wheels
Postby mikeschn » Sat Jun 11, 2011 12:17 pm
I'm playing with epoxy this morning!
I've used epoxy on fiberglass and canvas!
I have to let the resin harden overnight, so I should have some preliminary results tomorrow morning!
Images: 479
Postby GPW » Sat Jun 11, 2011 2:14 pm
Mike , I can see where a perforating tool and epoxy would make one STRONG skin ... canvas or fiberglass ... thousands of little epoxy "nails" deep into the Foam holding the skin on... Just something else to try on scraps ... :thinking:
