anyone seen this?
anyone seen this?
Postby aratman » Wed Jul 06, 2011 8:33 pm
Has anyone seen one of these or is there a build?
Don
aratman
Postby doug hodder » Sun Jul 10, 2011 11:34 am
I haven't seen one of those, but do like the lines on it. Got a name for it? Doug
Postby ATXKJ » Sun Jul 10, 2011 6:50 pm
I'm pretty sure someone posted a link in one of the Winter Warrior threads - but I can't find it now.
Google found this
http://atomicaddiction.blogspot.com/2009/07/best-pop-up-camper-ever.html
but if you search for 'Odyssey' travel trailers - you get Australia.
David
ATXKJ
that site is where i saw it
Postby aratman » Tue Jul 12, 2011 9:38 pm
I was hoping for more info
aratman
Re: anyone seen this?
Postby Shadow98258 » Sun Feb 24, 2013 8:18 pm
Ok so that blog does not exist anymore. Any other info on this trailer? It looks awesome and reminds me of a 50's era Corvette. I would like to see it set up. Where were these pics taken?
Shadow98258
Postby logman7777 » Thu Feb 28, 2013 7:28 pm
Should be able to emulate the lines with stick and ply construction. I did a search myself about a year ago when the wild goose profile was rambling around in my brain. Didnt come up with anything different than you did. Good Luck searching or building one!
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Postby bgordon » Tue Mar 26, 2013 7:19 am
Hi,
It is called the "Odyssey". Was built in the late 1950's.
I have never seen the inside. I mailed the guy who's trailer that is (when the thread was still live), but he never opened the trailer up.
I have a few other photos of the trailer. I'll see if I can find it.....
Barrie
Keep moving forward.
Psalm 1:1-3.
Build Journal: bgordon's 5 week cardboard & fiberglass build
http://www.tnttt.com/viewtopic.php?f=50&t=38781
bgordon
Images: 122
Postby PKCSPT » Tue Mar 26, 2013 7:32 pm
I really like the loo, hope someone builds one someday
121172 116946 159644
PKCSPT
Images: 61
Postby bgordon » Wed Mar 27, 2013 5:10 am
Hi,
I found this image of the patent document in my album. Still looking for the other pics...
Barrie
Psalm 1:1-3.
bgordon
Images: 122
Postby bgordon » Wed Mar 27, 2013 5:23 am
Hi,
By the way, I wanted to build something like this, but on a smaller scale. I crunched the numbers, and realized that this design will only work if the trailer is as long as the original Odyssey (about 16 feet, if my memory serves me right). I tried to adapt the trailer for a ten footer, but if the length is shortened to ten feet, the roof will not lift high enough for a person to stand in.
The second problem is packing space. In the original Odyssey this wouldn't have been a problem, since it is huge. If it is scaled down, packing space becomes a problem.
If someone can adapt this to a smaller dimension, it would be cool. However, as far as practical and small designs are concerned, I think Mike's Rockhopper is probably a better design.
Barrie
Psalm 1:1-3.
bgordon
Images: 122
Postby bgordon » Wed Mar 27, 2013 6:06 am
Hi,
Okay, here it is, as promised...
I even did a mockup of this on SketchUp... (In 2008).
Lastly, and probably most important: the patent number. 2,920,919. If you search the US Patent Office, you can see exactly how it worked...
Barrie
Psalm 1:1-3.
bgordon
Images: 122
Postby rmclarke » Wed Mar 27, 2013 10:18 pm
Barrie,
Thanks for posting those pics....I have been looking for that design for some time. I think a design something like that could work rather well made of foam (at least the top lifting part) and if the front was hinged a lot lower down, ample headroom could probably be created with a shorter overall length if the front profile was changed enough......off to the drawing board. :twisted:
rmclarke
Images: 231
Postby bgordon » Thu Mar 28, 2013 1:28 am
Hi,
I am glad I could help.
When you study the patent documents of the Odyssey, you will notice that the top of the trailer lifts at the back AND the front. . It does not simply hinge at the front, but lifts almost the entire height of the trailer. Doing something like this with a homebuild will certainly complicate the build considerably. That is why I believe that Mike's Rockhopper design is better suited to homebuilders. The front of the Rockhopper is much higher than the Odyssey, which allows for a simple hinge and not the more difficult pulley lifting mechanism (at the front).
Barrie
Psalm 1:1-3.
bgordon
Images: 122
Postby mezmo » Thu Mar 28, 2013 1:41 am
Hi Barrie,
Thanks for posting the pics. I always thought the Odyssey an
interesting TT, but had only seen about three pics of it.
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby bgordon » Thu Mar 28, 2013 2:41 am
By the way, the SketchUp picture of the Odyssey (above) is where I tried to shorten it. In that picture the trailer was shortened to 12 feet, or 3.6m.
The Odyssey design might work as a homebuilt if the front profile is heightened (made higher). Doing that will essentially transform the Odyssey into Mike's Rockhopper. Personally I would have hinged the Rockhopper more to the front, which would have given more headroom.
I would have hinged the Rockhopper something like this (notice the grey line):
Barrie
Psalm 1:1-3.
bgordon
Images: 122
