hwff wrote:It would help to have some parameters to better answer your questions:
Is the weight very important?
Will the coating need to stick to anything besides foam and wood?
Will they be getting banged into a lot?
Any other characteristics you are looking for in a coating?
What is being used to coat the foamies now?
Not to be contrary to what Louella posted, but here are my answers:
Is the weight very important? For some, yes it is. For me personally, no
Will the coating need to stick to anything besides foam and wood? Mostly foam and wood. Some are talking about aluminum in places but by far and away, foam and wood are the main components.
Will they be getting banged into a lot? Just normal banging into that any travel trailer might experience. I guess the biggest issue might be road debris such as rocks and the like. After awhile, whether you have a fiberglass trailer or aluminum sided trailer, it will experience damage depending on the size and velocity of object. I think we're just worried about the "normal" stuff.
Any other characteristics you are looking for in a coating? Just what you would want/expect from any outside skin of a trailer, things such as strength, durability, some flexibility, water tightness, holds up to the sun (good paint should take care of that issue). For myself and a few others, exterior finish (rough vs. smooth) is a consideration. For others, this is not an issue.
What is being used to coat the foamies now? Most, if not all, the Foamies currently under build or completed have used canvas with either Tite Bond II glue or exterior paint to provide adhesion.
Thanks so much for taking the time to answer our questions. I am very intrigued by the possibilities, I guess I just need some professional reassurance that what I am trying to do isn't outside of the design parameters and capabilities of the product.
