droid, thanks! No problem just never really read into any lift choices.
Don't have a garage so i will have to come up with something.
Treeview wrote:Using the rafters/trusses in a garage as a hoist point is sure tempting.
Be very careful though. building design is based on compression, snow/wind load. Adding a tension/pulling load where it isn't supposed to be can lead to collapse.
Without knowing what the rafter/trusses are rated for I'd be super cautious.
There are ways to add strength to rafters/trusses too. Plywood sheeting to tie them together, cross bracing...get hold of an educated carpenter, not just a person who hides nails.
Looks great on your truck. Of course you know we need more photos. Like with the unit open on your truck for example.rdraider wrote:Well, got her loaded. Now to take her out and see what works and what doesn't and make changes along the way.
Loaded! by rdraider72, on Flickr
