kbuddy wrote:How high do you normally keep the threshold of the door above the floor?
pohukai wrote:Is there a reason for using glass instead of just epoxy? I used polyester resign under my TD instead of the black goo and didn't have any problems. I use glass to add strength and the epoxy for encapsulating/water proofing and to bond the glass to the wood.
When I was glassing my kayaks, I realized that if you can get the glass to lay flat while dry, you'll never be able to get it to lay flat after it is wet. Fighting with wet glass is no fun as when I had to do the inside waterline seam while mating the deck with the hull of a kayak.
