mikeschn wrote:He welded the torsion axle to the frame.
Cary Winch wrote:Jakob,
Your questions is not crazy at all. The 2,000lb number is the total loaded limit of the trailer weight. The closer you get to that number the less it will bounce. But, you don't want to get too close and go over. We use the 2,000lb units and most of our trailers weigh in about 900lb-1,100lb empty. This seems to be the sweet spot where is starts riding smooth. We make some base models that are closer to 700-750lb and they ride a bit bouncy. A loaded 1,500lb-1,600lb tear with a 2,000lb axle should ride real nice.
Cary
Mike wrote:... so does that make us more sophisticated like those folks in Yurp?
Mike the smart-ass show-off wrote:Al Kon habe ich nicht verstanden... kannst du das fur mich ubersetzen?
