Hello again,
This winter I attached a hitch to my Honda ST 1100 motorbike and now I want to build a 3.3 x 6.6 foot Micro-Airstream to pull it behind my bike.
The german technical commission (TÜV) allows me to tow 190 kg (418 lb) behind my Honda and I hope to meet 300 lb with my tiny Airstream.
I like the polished look of the Airstreams, but I don't want to polish my can twice a year.
So stainless steel will be the best for me, but 7.3 square meters will cost about 440 Euros in 0.6 mm thickness.
The ground frame will be 40 x 40 x 2 mm rectangular aluminum tubes, which will be welded together by a company for me.
The body should be removable and fixed at only four points to the ground frame. So its only cargo and not a vehicle.
We have strong regulations in Germany for additional lighting and plexiglass windows used in vehicles.
But if the can is only transported as a box on a platform trailer, I'm free in design, material and lighting.
The floor will be one big sheet of 2 m x 1 m x 1.5 mm aluminum treadplate.
The wall frame I will build from 20 x 20 x 1.5 mm rectangular aluminum tubing.
And the curved roof and corner frames will be from 15 x 15 x 1 mm rectangular aluminum tubes, wich I can bend by myself over a pattern.
The stainless skin I will fix with 4mm waterproof rivets to the frame. The biggest problem I fear are the four 3-D roof corners with one foot radius.
I have to test it with a sheet of paper, then aluminum to find a cutting pattern that will work at the end for the stainless steel too.
But first of all I will get axle, tongue and wheels next Tuesday or Wednesday.
Today my supplier confirmed the delivery date off the factory next monday !
Tom from Bavaria
