Aw, come on Ira...tell them why you didn't buy the combo.
surveytech wrote:Ira wrote:Actually Walter, since my stuff bends so easily anyway, I probably don't have to prebend it. Why not just glue it down and strap?
Also, what do you think--a job for Titebond, right? No sense in messing with poly stuff for this.
I used Titebond III on mine but I also used screws and staples. I bet either glue would work.
Mitheral wrote:
Titebond creeps and is water resistant not water proof. I'd go for the PU for fenders.
angib wrote:Boatbuilding method for this sort of job: fix thin ply down with a staple gun and then remove the staples when the glue is set. How? You can prise each staple out, but it'll probably mark the ply. Instead fire the staples through a piece of packing/banding strap (the unbreakable polypropylene stuff) - once the glue has set, yank (or hoick, or yark) on the strap and it'll pull the staples out in one go.
