The
Jordan Ultima applies braking power which is proportional to the distance the brake pedal is depressed. This isn't ideal because changes in boost change the pedal travel required to have a given braking effect in the tug... which is why responding to the tug's hydraulic pressure is better. Still, some users of this product swear by it.
Systems tapped into the tug's brake lines to read that
pressure seem to be nearly gone. The
BrakeSmart from Master Brake may be the last holdout. The auto manufacturers don't want devices interfering with their increasingly sophisticated braking systems, so the aftermarket gave up on what was a common approach. I didn't get the BrakeSmart because I had not found it at the time I bought a controller, and I would be hesitant to tap into my new van's brake system, anyway.
The Ford (and perhaps GM)
built-in brake controllers do respond to brake line pressure, but are only available on "heavy duty" (SuperDuty Fords, HD from GM) pickup trucks (and maybe SUVs).
The closest remaining thing I've found is one system which responds to the force of your foot on the pedal, using a
pressure-sensitive pad. This is the
EVO from
Sens-a-Brake. It makes a lot of sense to me if the BrakeSmart is not available or practical for your vehicle. Read their website and you'll know as much as I do...
The hills don't eliminate systems which are
proportional to acceleration. Skip the old pendulum-based designs, and pick anything using a two-axis accelerometer, such as the extremely common Cequent (Tekonsha) Prodigy or their newer P3. I use a Prodigy, and believe that it's a critical component of the braking system and in no way is it "overkill".
