Kullas wrote:Heart of Gold the spaceship in the book The Hitchhiker's Guide to the Galaxy
jeporter25 wrote:Thanks Drew. I was also wondering if you had a gap at the edges of the aluminum on the top or was it a little wider than 5 ft?. I was wondering because your side walls overlap the NT trailer frame and I know that it is 5" wide. I did not see an easy way to make the trailer less wide so I was wondering it the Aluminum is just close enough and the trim takes care of the rest?
drewh1 wrote:... and will eventually stop obsessing about all the mistakes and extra holes!
you can get a pin that fits tight in the holes for the hitch and the noise should go away and make sure the hitch is on the ball tight there might be a adjustment nut under the tounge on trailer tighten it tell it fits good and snug.
