Largest Foamie ?
Largest Foamie ?
Postby GrenDesb » Fri Oct 21, 2016 2:04 pm
What size is the largest foamie ever built?
Specifying if an internal structure was used or not.
GrenDesb
Re: Largest Foamie ?
Postby KCStudly » Fri Oct 21, 2016 2:15 pm
I would think it has to be the FoamStream, by GPW.
Postby tac422 » Fri Oct 21, 2016 4:32 pm
The Big Pink is 5x10.
tac422
Postby Don L. » Fri Oct 21, 2016 7:09 pm
Painting foamie.jpg (241.33 KiB) Viewed 3965 times
This probably isn't the biggest but I think it is pushing the limits. It is 78" wide x 12' at the longest point, about 10' long where it rests on the chassis. About 90" tall from the ground.
It is almost painted completely. One more side to go, that hasn't stopped us from going camping though.
Link to my foamie camper build viewtopic.php?f=55&t=67321
instagram #don_leister_violin.rva
Don L.
Postby Andrew Herrick » Fri Oct 21, 2016 7:16 pm
That is awesome! Is the mural hand painted?
A few of my builds:
Andrew Herrick
Images: 15
Postby Don L. » Fri Oct 21, 2016 7:28 pm
Yes, my wife is working on the front. There is another picture of it in the thread about 'Paint protection...' that I just started.
Don L.
Postby tac422 » Fri Oct 21, 2016 10:46 pm
Wow, why haven't I seen this before ?
This is great, and in Virginia too! (we're in Tidewater)
Don L. wrote:
tac422
Postby GPW » Sat Oct 22, 2016 5:24 am
Great paint job !!! :thumbsup: 8) :applause: That is a BIG Foamie !!!
Postby WizardOfOdds » Sat Oct 22, 2016 7:37 am
I'll 2nd that comment. You might want to comment on the original question:
Maybe you have the details on any internal framing in one of your threads, so it might just require a link.
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 43
Postby Don L. » Sat Oct 22, 2016 12:44 pm
Camper side profile.jpg (144.7 KiB) Viewed 3859 times
Inside camper.jpg (170.32 KiB) Viewed 3859 times
Inside back of camper.jpg (166.13 KiB) Viewed 3859 times
I was just taking some interior pics so you could see the cabinets inside which were built with idea of structural strength in mind.
I have no other threads going about this by the way.
The lower cabinets and drawers are made with 3/4" plywood and screwed to the 3/4" plywood floor using LOTS of 'L' shaped framing fasteners. Upper cabinets are made of 1/4" plywood wherever possible and 1x facing, with special attention paid to gluing and fastening and making them as strong as possible.
All the cabinet backs were 1/4" plywood screwed into the wall with those metal self drilling anchors (glued in with gorilla glue) and also glued against the wall with adhesive caulk like polyseamseal or such.
Also, I hope the pictures show it, there are wall ledgers here and there to hold up the small upper cabinets and the bunk and also to put pegs into. The pegs see a lot of use from, towels, hats, clothes, you name it.
Don L.
Postby Don L. » Sat Oct 22, 2016 1:04 pm
Hopefully this shows how some of it is built. You can barely see the metal connectors where the cabinets meet the floor, I put in as many as would fit, apparently after this photo was taken.
camper framing.jpg (87.6 KiB) Viewed 3879 times
camper cab..jpg (116.91 KiB) Viewed 3879 times
camper building.jpg (89.27 KiB) Viewed 3879 times
Don L.
Postby Don L. » Sat Oct 22, 2016 1:39 pm
I'll start a thread about my build, called 'Bluebird' and put more photos in that. That way my pics won't be scattered all over the place and devices of mine.
Don L.
Postby Camp4Life » Mon Oct 24, 2016 12:35 pm
Good lord! That is a big foamie! I'm impressed :applause: How does it handle on the highway?
Camp4Life
Postby Don L. » Mon Oct 24, 2016 5:15 pm
Generally it's good on the highway but there is a concern, occasional sway when a semi passes me especially if the road is not well maintained. I could live with it, but will try some different weight distributions and if it is still bothersome I may see about swayers.
I have not had it in any big crosswinds. It's kind of a heavy foamy. I'm thinking 1,200-1,400 pounds loaded maybe?
Don L.
Postby rowerwet » Tue Oct 25, 2016 8:50 pm
Mercury is 6.5x13' ,the walls are 4 feet tall. The only structure is a wall of 2" foam running across at the back of the forward doors, the galley wall, also foam, some plywood strips that are glue bolted to the galley wall and side walls to support the galley shelf, and the galley opening frame for the hatch.
Each main door has a plywood ring that rests on the floor and runs up to support the roof and the spars over the door area.
There are 1x3 roof spars notched into the foam to support the roof, as it has a second story planned but not yet built
rowerwet
Images: 521
