The specs on the website say the overall width of the Ironton 5x8 trailer is 76". The tires are 5.6" wide each, so it figures out to 64.8" between the tires.
Can anyone confirm that the actual width between tires on a stock NT 5x8 matches this?
How much clearance is needed between the side of the body and the tire? I'm trying to determine the maximum width that the body can be, which figures to be 64.8 - (2 x clearance).
I'm looking at making my deck exactly 5' wide (1 1/2" thick sip), then adding a 1 x 6 (3/4" x 5 1/2") skirt around it to overhang the trailer frame, locking it down. That makes it 61 1/2" wide. Then the idea is to attach the body shell thru a 1/16" diamond plate finish skirt thru the foam, the 3/4" skirt, and the trailer frame. This gives me an inside width of 61 1/2", but 65 5/8" outside width (I'm planning a foamie build with 2" foamboard).
- BodyAttachment.png (5.03 KiB) Viewed 4411 times
I guess if its necessary I could eliminate the wood skirt, which reduces the body width by 1 1/2", but it still comes out to 64 1/8" width, which would only give about 3/8" clearance each side.
Does anyone see any issues with using wheel spacers to widen the track? I found some on ebay that were 1 1/4" thick, which would add 2 1/2" to the track width. These would also allow me to move up to 14" wheels/tires.
Thanks
